F-Series Keyless
1) Connect IDS and identify vehicle
2) Select the toolbox icon in top
3) Select Body from the drop down menu
4) Select Security from the drop down menu
5) Select Factory Keyless Entry Code from the drop down menu
6) Click the tic button and follow the on screen instructions
-OR- (if that option is not available)
3) Select Data Logger from the drop down menu
4) Select Modules from the drop down menu
5) Select VSM from the drop down menu
6) Look for and highlight the Keycode PID and select the tic button to initialize. The code should be displayed.
Quote:
Programming Personal Codes
A unique personal 5-digit code can be programmed by following these steps:
1)Enter the factory set 5-digit code (the RKE keypad will illuminate when pressed).
2)Press the 1/2 button within 5 seconds of Step 1.
3)Enter the unique 5-digit code.
The personal code does not substitute for the permanent factory set code. Either code can be used to access the vehicle. In addition, if a second personal code is programmed, it will simply overwrite the previous personal code.
