Keith Browning Posted October 10, 2007 Share Posted October 10, 2007 All years, knocking sound on drivers side which is really annoying. Sounds like its in the area of the brake pedal or even the cab hinge. Apply grease to the cab prop in all three hinge areas. You may need to remove the pins to get the grease in there. Use something thick and not too much. The grease will make the parts stick to each other and prevent the prop from hopping around and making noise. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted March 14, 2008 Author Share Posted March 14, 2008 Oh lookie! It's a TSB now. 2006-2007 TSB 08-06-05 LCF - RATTLE UNDER CAB OVER BUMPS - BUILT ON OR BEFORE 12/3/2007 I thought of using washers in the prop hinges but I didn't have anything that worked. The grease was a last attempt idea before accepting defeat... after all, the customer wasn't complaining, it just annoyed ME while on a road test. Quote Link to comment Share on other sites More sharing options...
