d-rings
W302290 are the small rings on the bottom of the stand pipe and the bottom of the 2 piece stand pipe.
W301390 is the ring at the top of the dummy plug and the top of the 2 piece stand pipe.
W301386 is the ring in the middle of the 2 piece stand pipe and the bottom of the dummy plug.
I am fairly certain those numbers are right but I'm not at work right now and can't be sure--I'll double check tomorrow unless someone else can confirm that info.
They are called D-rings because if you look at a crosssection of the o-ring they look like a D. Flat on the back where they mount and round on the outside where they seal.
