Keith Browning Posted November 13, 2007 Share Posted November 13, 2007 I have an F550 with a repeat EGR valve failure in 900 miles. The pinpoint tests were straight forward and I couldn't command the valve to move. I decided to pick up the phone and call the fellas at the Hotline. Supposedly they have some reports of DOC failures - told me to check for a whitish powder. Also, the possibility of an EGR cooler going bad was mentioned. I thought this style of EGR valve was supposed to be more robust. /forums/images/%%GRAEMLIN_URL%%/scratchhead.gif I think there is more to this truck than its letting me see. Quote Link to comment Share on other sites More sharing options...
OHNO60 Posted November 13, 2007 Share Posted November 13, 2007 i agree keith! i have an 08 built in feb and it has a slight fuel knock in the 2100 rpm range.no dtc's passed high pressure fuel test with flying colors.contact hotline and tell them my shrt term fuel for number 2 is +7 when others are -2,0,etc and they instructed me toi check for a backlash uissue with the hp pump and the knock could be the lash issue,ahahahaha. gotta love it. i anticipated better for the 6.4 too. /forums/images/%%GRAEMLIN_URL%%/banghead.gif Quote Link to comment Share on other sites More sharing options...
snw blue by you Posted November 13, 2007 Share Posted November 13, 2007 Where is the white residue, in the EGR valve? Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted November 13, 2007 Author Share Posted November 13, 2007 I guess that is where. If the DOC breaks up the chunks wont pass through the cooler so as it bounces around it probably gets pulverized into powder. I saw some whiteness around the outside of the valve but I attributed that to condensation and aluminum. The coolant level was not low so I didn't have any reason to keep digging. If it comes back I'm going to ask what THEY want me to replace. Quote Link to comment Share on other sites More sharing options...
DieselD Posted November 19, 2007 Share Posted November 19, 2007 check your fuel quality and cetane rating. higher than ultra low sulfer fuels will cause repeat egr failures Quote Link to comment Share on other sites More sharing options...
