OHNO60 Posted December 7, 2007 Share Posted December 7, 2007 ANY OF YOU GUYS HAVE HEARD OF A BACKLASH ISSUE WITH THE HP PUMPS ON THE 6.4 CAUSING A SOUND SIMILAR TO A FUEL KNOCK? TECH LINE SAID HAD ISSUES ABOUT THIS.TRUCK HAS WHAT SOUNDS LIKE A FUEL KNOCK AND ALL READINGS NORMAL. Quote Link to comment Share on other sites More sharing options...
sdtheclub Posted December 23, 2007 Share Posted December 23, 2007 Wow I would be surprised if that ended up causing a fuel knock. Haven't seen any with fuel knocks yet. Let us know what you end up finding. Good luck Quote Link to comment Share on other sites More sharing options...
Skidonenko Posted December 23, 2007 Share Posted December 23, 2007 I have one stiing at work that just came in. WHen it is hot it sounds like a sparkplug wire arching. It is not a steady pop but is more consistant at 1k rpms. wierd ass sound Quote Link to comment Share on other sites More sharing options...
OHNO60 Posted December 24, 2007 Author Share Posted December 24, 2007 I WAS DAM SURE IT WAS A FUEL KNOCK.SENT IN ALL IDS READINGS TO HOTLINE GUYS AND ALL ARE NORMAL. FOR SOME REASON THEY CLAIM THERE HAS BEEN A LARGE NUMBER OF 6.4'S PRE JUNE 2007 WITH THE CONCERN AND ENDED UP BEING THE BACKLASH HP PUMP TO CAM GEAR??? HOTLINE STATES COMMAND HP PRESSURE TO MAX AND LISTEN AT TRANSMISSION. JUST CURIOUS IF YOU GUYS SEEN THIS. BY THE WAY SOUND IS LOUDEST WHILE ACCELERATING AND A CAR OR DIVIDER NEXT TO YOU REFLECTING SOUND BACK. Quote Link to comment Share on other sites More sharing options...
