Hempstead Posted December 29, 2007 Share Posted December 29, 2007 I just lifted my first excursion body today and was wondering if the body bolts are suppose to be different head size from side to side. Lifting the body is the best I wish I started lifting cabs years ago. Quote Link to comment Share on other sites More sharing options...
G. Bedford Posted December 29, 2007 Share Posted December 29, 2007 I seem to remember using a 24mm socket on the drivers side bolts and a 21 mm socket on those on the passenger side. It's been awhile since I did a excursion,though. Quote Link to comment Share on other sites More sharing options...
Mekanik Posted December 29, 2007 Share Posted December 29, 2007 Yes. all of the excursion and f series trucks that I have removed bodies are like this. Quote Link to comment Share on other sites More sharing options...
Hempstead Posted December 29, 2007 Author Share Posted December 29, 2007 Thanks! I was hopeing that was the way they were suppose to be and not some misbuilt truck. Quote Link to comment Share on other sites More sharing options...
snw blue by you Posted December 29, 2007 Share Posted December 29, 2007 Completely normal. I've asked why but have yet to recieve an answer. Now, on an '08 if you have to access the nuts, they are all 21mm and BTW if you get involved in one of these, the second set of nuts (under the drivers and passengers footwells) can be accessed just like you would on the previous generation bodies. Do not! I repeat, do not try and access them as instructed in the TSB, (Remove inner fender and access through hole) It is an aggravating waste of time. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted December 31, 2007 Share Posted December 31, 2007 I think the factory only has one 21 mm socket and they got tired of passing the air gun back and forth. Quote Link to comment Share on other sites More sharing options...
