ablokzyl Posted December 30, 2007 Share Posted December 30, 2007 I have an 03 F550 6.0l that wont start. I diagnosed it to be an inop cam sensor. When I went to pull it out it broke off flush with the block. Hotline says to drill it out, but I dont know how much good thats gonna do. Does anyone have any ideas on how to remove it? Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted December 30, 2007 Share Posted December 30, 2007 Any chance of getting a o'ring pick up there to get it out? Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted December 30, 2007 Share Posted December 30, 2007 Yuck. Heat up a long thin sheet metal screw and twist it into the broken stub. Let it cool and pry the bastard out. Good Luck! /forums/images/%%GRAEMLIN_URL%%/grin.gif Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted December 30, 2007 Share Posted December 30, 2007 I haven't had the pleasure - but here's what I'd probably try... Using about a 1/8th bit, drill into it about 3/4 inch or so.... bottom a #8 sheetmetal screw in it (choose one long enough so you have a good purchase point for later....). Soak it with Kroil and leave it for a while.... Soak it with Kroil again and leave it for another while. See if you can get it to turn using your embedded screw.... Getting it to turn will be the first step towards success... Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted December 30, 2007 Share Posted December 30, 2007 Wow! A cam sensor? I have broken half a dozen crank sensors but never one of those. I hope the tip isn't damaged from being hit by the timing pin on the camshaft. Bruce's idea is probably the best idea. When I break a crank sensor the guts usually come out with the top of the sensor. I thread a tap into the cup that is left behind and usually that does the trick. Quote Link to comment Share on other sites More sharing options...
ablokzyl Posted December 30, 2007 Author Share Posted December 30, 2007 Well i screwed a 3 inch screw in about an inch and a half then put a pair of visegrips on the screw for something to pry against. I then pried with my 3 foot bar and it wouldnt budge. Ive been spraying it with BG penatrating oil for a few days but it still wont move. The hotline engineer says that the inner o-ring is the one that is stuck. Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted December 30, 2007 Share Posted December 30, 2007 Sounds like Fire Wrench time /forums/images/%%GRAEMLIN_URL%%/flamethrower.gif Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted December 30, 2007 Share Posted December 30, 2007 Try the Kroil... this is the stuff in the orange can for the 5.4 spark plugs... this stuff can be amazing... Try to get the sensor to turn. This will help break the O-ring loose. Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted December 30, 2007 Share Posted December 30, 2007 Kroil/PB blaster the saga goes on, who's better??? That's up to each persons preference. I like PB but then there is Kroil also. It's all up to your individual preference... Quote Link to comment Share on other sites More sharing options...
Aaron_Johnson Posted December 30, 2007 Share Posted December 30, 2007 Like Jim says get it turning and use a good penetrating oil....I prefer the cxc-51A Ford stuff. I had one break off on me like that. I took the p/s pump off,threaded in a long screw and made a short little slide hammer out of 5/16 rod,some washers and a heavy socket. It worked for me but sounds like yours is siezed worse than mine was. Good luck Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted December 30, 2007 Share Posted December 30, 2007 Quote: NASCAR Canadian Tire Series crew member /forums/images/%%GRAEMLIN_URL%%/scratchhead.gifIsn't that supposed to be CASCAR? /forums/images/%%GRAEMLIN_URL%%/scratchhead.gifGood idea with the slide hammer!!! /forums/images/%%GRAEMLIN_URL%%/thumbup.gif Quote Link to comment Share on other sites More sharing options...
ablokzyl Posted December 31, 2007 Author Share Posted December 31, 2007 Well thanks guys, Ill go in tomarrow and give your ideas a try. Quote Link to comment Share on other sites More sharing options...
Aaron_Johnson Posted December 31, 2007 Share Posted December 31, 2007 LARRYATSTI It used to be CASCAR until NASCAR bought our series last fall /forums/images/%%GRAEMLIN_URL%%/smile.gif Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted December 31, 2007 Share Posted December 31, 2007 just had one like you did,take a look at my photos there is a cam sensor that got hit by the cam pin,I put a shortblock into it and was under cost cap so I did not have to get approval for it Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted December 31, 2007 Share Posted December 31, 2007 Quote: LARRYATSTI It used to be CASCAR until NASCAR bought our series last fall _________________________ Ford Master Tech NASCAR Canadian Tire Series crew member Snap-on KRL700 series Rusty Wallace limited edition Ahhh that explains the Rusty Wallace tool box!!! I was wondering about that too!!! Quote Link to comment Share on other sites More sharing options...
ablokzyl Posted January 2, 2008 Author Share Posted January 2, 2008 Just thought that I would tell you that I finally got the broken sensor out. I ended up making a slide hammer out of a long sheetrock screw and a heavy socket like was suggested in an earlier post. That worked like a charm. Thanks for all the help. Quote Link to comment Share on other sites More sharing options...
jhd Posted January 8, 2008 Share Posted January 8, 2008 Have had several plow trucks break the cam sensor,remove all but one with heating a pick and jamming it in sensor let it cool and carefuuly removedthem.The other one i ended up replacing the shortblock Quote Link to comment Share on other sites More sharing options...
