Engine for sale...
DamageINC
I know this isn't the yellow pages or Craigslist or anything, but this site has it's fair-share of hot-rodders and I figured I'd mention this..
Buddy of mine has a badass 4.6 for sale NEVER BEEN RUN, basically:
'99 Cobra block ("Teskid" motor, basically indestructible block)
.020" over (283 cid)
Polished/rebalanced crank
H-beam rods
9:1 Forged pistons
Stock 4v Cobra heads/cams
*COMPLETE* all the way from the throttle body to the oil pan. Comes with Cluster, PCM, wiring, everything you would need to drip this engine into virtually anything.
It's a lower-compression 4-valve built-to-the-hilt and will handle over 1,000 hp all day long. As it sits, it probably only makes just shy of 300 in it's naturally asiprated form, but this engine was built for one thing, and a lot of that one thing -
Boost.
So, if you have any itching to build yourself a retardedly powerful turbo 4.6 (a single 76mm or a couple smaller twins will but a big smile on ya) street car, let me know!
A good 22-23psi from a properly sized turbo(s) or blower will net you around 800hp at the crank on this engine, and it will be totally streetable on pump-gas, as long as you get a good safe/conservative tune.
Located in the Chicago area, if you're interested...
Dave
I think we should all pitch in and build something for "Pinks". I'll bet that my boss would be willing to throw a turbo or 2 at it....
Can anybody else pitch in???
Just think about it a DTS powered car/truck. how cool would that be???
