Jeff_ Posted January 15, 2008 Share Posted January 15, 2008 Well, I've never run across this before in my travels. I'm replacing a Hp pump in an 03 7.3 F350 and I apparently have 2 possible pump to cover gaskets to choose from. The one on the left is the one that came with the reman pump, and the one on the right is identical to the one I just removed from the truck. Does anyone know why there is a difference, and what will happen if i choose wrong????? [url=http://img170.imageshack.us/my.php?image=73hppumpgasketsha4.jpg[/url] Quote Link to comment Share on other sites More sharing options...
snw blue by you Posted January 15, 2008 Share Posted January 15, 2008 For my money I'd use the the style that was already installed. Is there anything different about the pump? Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted January 15, 2008 Share Posted January 15, 2008 Jeff use only the one on the right side, the left side is for the older syle pump F4TZ-BRM. If the left side gasket came with the pump I think you should check that you got the correct pump as well. Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted January 15, 2008 Author Share Posted January 15, 2008 Thanks guys, I used the one on the right (like what I removed) and it runs great. /forums/images/%%GRAEMLIN_URL%%/thumbup.gif Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted January 15, 2008 Author Share Posted January 15, 2008 The pumps appeared to be identical Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted January 15, 2008 Share Posted January 15, 2008 Look on page 43 of the 98 99.5 7.3 DIT Direct Injection Turbocharged Diesel coffee table book. It has the explanation and photographs. Oh, the book is 39Mb so it will take a few minutes to download depending on you Internet connection. The coffee table books are accessible on the lower right of this page under Tech Recourses. Quote Link to comment Share on other sites More sharing options...
