Jeff_ Posted January 15, 2008 Share Posted January 15, 2008 I thought you guys may be interested in this. This customer was complaining of an oil leak. With the help of an inspection mirror and a light, I traced it to the drain tube o-ring for the HP turbo. Never having seen this problem before, I thought I'd share. The replacement o-ring is black rather than green so hopefully that means they improved it. Quote Link to comment Share on other sites More sharing options...
Matt Posted January 16, 2008 Share Posted January 16, 2008 Thanks for sharing. I havn't had to do much other than radiators in 6.4 so far. but people like you just sharring info like this helps everybody out. thanks again Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted January 17, 2008 Author Share Posted January 17, 2008 Welcome Aboard Matt!!! I like your avatar, you'll fit in very well here /forums/images/%%GRAEMLIN_URL%%/cheers.gif Quote Link to comment Share on other sites More sharing options...
Matt Posted January 17, 2008 Share Posted January 17, 2008 Thanks jeff my nickname has been bert for awhile. So the avatar is very fitting. Quote Link to comment Share on other sites More sharing options...
kmack4 Posted January 22, 2008 Share Posted January 22, 2008 MY FIRST 6.4 OIL LEAK AT 2100MILES WAS SAME.HAD TO PULL CAB THIS WAS BEFORE IN CAB REMOVAL PUBLISHED.YOU THINK THEY WOULD HAVE PUT A STUD IN TO ANCHOR DRAIN TUBE, BOSS IS ALREADY ON TUBE! Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted January 22, 2008 Share Posted January 22, 2008 There is a reason that tube is not bolted down. In the early units it was bolted down and this caused a leak due to the turbo and drain tube heating up and expanding at different rates which would kick the drain tube over slightly and it would leak past the "o"-ring. With that tube not bolted down it can flex side to side as the turbo heats up and keep the "o"-ring centered. Quote Link to comment Share on other sites More sharing options...
