OHNO60 Posted January 25, 2008 Share Posted January 25, 2008 ANYBODY REMEMBER THE MAX DIFFERENCE BETWEEN ECT AND EOT? Quote Link to comment Share on other sites More sharing options...
Guest Posted January 25, 2008 Share Posted January 25, 2008 i believe the eot max that the pcm will allow before it defuels is 252.. water temp has to be between 240 and 250 also.. Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted January 25, 2008 Share Posted January 25, 2008 TSB 07-21-5 states that EOT should be about 225 when ECT is 200 degrees Farenheit. And if there is more than a 25 degree spread during the concern to replace the oil cooler...but only after performing the other steps in the diagnostic procedure. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted January 25, 2008 Share Posted January 25, 2008 Outstanding! Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted January 25, 2008 Share Posted January 25, 2008 Standingout! Quote Link to comment Share on other sites More sharing options...
Tony302600 Posted January 25, 2008 Share Posted January 25, 2008 Im going to tell you what the hotline guys told...every single one said 10degrees difference is questionable 15 requires replacement. 25 is both totally gone. Quote Link to comment Share on other sites More sharing options...
