DamageINC Posted January 26, 2008 Share Posted January 26, 2008 Got an '05 E-350, 34,000 miles, check eng light on. Customer has not had any driveability concerns at all, aside from the light. Only code in the system is a CMDTC/P0341 (cam sensor skt code) but passes all on-demand tests. Freeze Frame data shows that it probably threw the code on a startup, so maybe the guy was cranking the hell out of it?? It's been *VERY* cold out here lately, (ambient has been anywhere from 0*F to -12*F). Either way, engine runnign time was 00:00:00, ECT was at 48*F (guess it'd been sitting for a short while), VSS was 0mph.. ..Just for grins I drove it around and monitored the RPM graph, which is looking completely normal, whether I'm cruising, parked, reverse, heavy or light load, it stays normal. Also kept an eye on SYNC and FICMSYNC (changed the pids over to bar graphs, it's much easier to monitor those pids that way) and they were rock-solid as well. Ideas? Dave Quote Link to comment Share on other sites More sharing options...
