kellyf Posted January 26, 2008 Share Posted January 26, 2008 Does anyone know if you can replace the injector connector/s seperatly?I have one that someone mauled two connectors.pulled the pins out of one and just broke the otherone in half. Quote Link to comment Share on other sites More sharing options...
GregH Posted January 27, 2008 Share Posted January 27, 2008 If you can find the hardshells and the pins, you can rebuild the connectors yourself. I'd use an old FICM harness for parts if you cannot find teh parts new. However, the FICM harness is cheap, and it is absurdly easy to put in. By the time you add up your parts and labor, you'll probably come out about the same to replace the harness. And you'll get the vehicle out of your stall faster. Quote Link to comment Share on other sites More sharing options...
kellyf Posted January 27, 2008 Author Share Posted January 27, 2008 Thanks for the information. Quote Link to comment Share on other sites More sharing options...
