UBET Posted January 31, 2008 Share Posted January 31, 2008 hey guys doing my first 6.0l ambulancxe head gaskets,lookin at most of the pics theres a frt engine mount used to remove these engines is it necassary or i have a fork lift with a bar on the end?thanks any other tricks with these things just diassemblying frt end right now Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted January 31, 2008 Share Posted January 31, 2008 See the "engine cranes" thread in the Tools/Computers/internet section. It's pretty close to the top of the list. Quote Link to comment Share on other sites More sharing options...
Aaron_Johnson Posted February 1, 2008 Share Posted February 1, 2008 I use a palte I made that bolts to where the turbo pedastal does and use a forklift with one fork removed. I find it easier than the ford lifting tool. Quote Link to comment Share on other sites More sharing options...
UBET Posted February 1, 2008 Author Share Posted February 1, 2008 OH GOOD CAUSE THATS WHAT I HAVE MINUS THE PLATE BUT ILL BUILD ON E ONCE I GET TO THAT POINT IS IT EASIER ON THESE JUST TO GO BY SHOP MANUAL PROCEDURES?ANY SHORT CUTS? I WAS TOLD YOU COULD PULL MOTOR MOUNTS OUT BEFORE DISASSEMBLING TOP END?DOES THE MOTOR MOUNT ON THE FRAME SIDE HAVE TO COME OFF TOO?CAUSE I CANT GET THE ENGINE ANYWHERE NEAR HIGH ENOUGH,THANKS Quote Link to comment Share on other sites More sharing options...
RJP Posted February 1, 2008 Share Posted February 1, 2008 Yes remove both mounts, oil pan, & pick-up. Make sure you remove the ICP sensor in right valve cover to or you will brake it. Quote Link to comment Share on other sites More sharing options...
