sam Posted February 13, 2008 Share Posted February 13, 2008 I have this truck that came in and the customer is complaining about the wif light on, so i changed the fuel filters and drain the water seperator. he returns and says that is came back on, so like on the 6.0s i ordered the fuel header, while installing it i found a lot of gel/water in the lower part of the hfcm, cleaned it all out and replaced the header. drove it about 10 miles and no light, after the customer came and got it drove it 3 miles and the light came on, truck left but is coming back on thurs. have yall seen anything like this, can i get just the sensor or do i need to get the whole pump, have not seen any tsbs or ssms, or did i miss something. Quote Link to comment Share on other sites More sharing options...
hitechmech Posted February 13, 2008 Share Posted February 13, 2008 starting to see this more frequently on new vehicles mostly (low mileage) and finding water in fuel tank. once fullt cleaned out no more problems Quote Link to comment Share on other sites More sharing options...
sam Posted February 13, 2008 Author Share Posted February 13, 2008 SO i need to drain the tank and clean the lines fill with known clean diesel to keep this from happening. the vehicle only has 14590 miles on it. Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted February 13, 2008 Share Posted February 13, 2008 Any software updates for the instrument cluster? I think 04's had a similar deal for which there was a reflash. Quote Link to comment Share on other sites More sharing options...
sam Posted February 13, 2008 Author Share Posted February 13, 2008 when i get it back in here i will check for updates and see if there is water that will drian out of the seperator, Keep all suggestions comming. Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted February 14, 2008 Share Posted February 14, 2008 Sam the question I have does your customer usually have full tanks or partially filled where condensation can form in the tank? If it forms on the top of the tank it won't always drop down into the fuel, which could be the reason for the comebacks. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted February 14, 2008 Share Posted February 14, 2008 Sam, I realize that this is a 2008 truck that you are working on but the basic concern is the same as prior Super Duty trucks. We have seen a lot of that cheesy build up in the water collection chambers which reduces the capacity of water it can hold. But removing the manifold and cleaning any contamination out is only a part of the repair. Inspect the WIF sensor for corrosion and sediment that could cause the light to stay on. The WIF sensor is serviceable on 6.0L level HFCM assemblies and I am thinking it might be for a 2008 as well. Please access and review TSB 06-22-12 for details on the procedures. The TSB wont cover a 2008 model truck and the part may not be applicable for a 2008 but it will give the general idea. Warranty will not cover a new manifold under a warranty if the sensor is avaialble... I imagine the same is true for a 2008 but if the sensor is not available then I guess you will need to replace the manifold. Quote Link to comment Share on other sites More sharing options...
sam Posted February 14, 2008 Author Share Posted February 14, 2008 i have already replaced the manifold, the sensor is not in the manifold on the 6.4 like on the 6.0, i beleive it is at the front of the pump, but parts does no have a listing for the sensor, Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted February 14, 2008 Share Posted February 14, 2008 Yes, it's in the fuel pump housing on the front side just under the pump itself. It does not appear to be serviceable. /forums/images/%%GRAEMLIN_URL%%/shrug.gif Good Luck! Quote Link to comment Share on other sites More sharing options...
sam Posted February 15, 2008 Author Share Posted February 15, 2008 thanks guys for all the help i will let you know what i end up doing to fix it when the customer brings it back. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted February 16, 2008 Share Posted February 16, 2008 i have already replaced the manifold, the sensor is not in the manifold on the 6.4 like on the 6.0, i beleive it is at the front of the pump, but parts does no have a listing for the sensor, As we can see by the pics the HFCM has been changed a lot! I have only drained the bowls on a couple but I did not snoop much. Good pics Bruce! Quote Link to comment Share on other sites More sharing options...
sam Posted February 16, 2008 Author Share Posted February 16, 2008 I tried to get the housing and ford says that it is obsilete, so i ended up ording the pump so when it gets here i will put it on and then explore the old pump and housing before i turn it in to parts. Quote Link to comment Share on other sites More sharing options...
sam Posted March 10, 2008 Author Share Posted March 10, 2008 ok its been awhile, but the truck came back finally, i replaced the fuel pump and reprogramed the pcm and ic. it has been about 2 wks now and no word of it. i think i fixed it.... we will see. Quote Link to comment Share on other sites More sharing options...
BrunoWilimek Posted March 10, 2008 Share Posted March 10, 2008 TSB 07-24-04 still applies to these 08 trucks. It involves removing the mushroom vent cap from the fuel tank and replacing it with a length of hose. The vent cap is in a location that allows melting snow to pool and be sucked in as water into the fuel tank. This may help keep the problem from re-occurring. Quote Link to comment Share on other sites More sharing options...
