FordMastertech Posted December 30, 2004 Share Posted December 30, 2004 I have a 04 F350 in the bay at this time with black goo in the cooling system. Ford hotline wants me to replace the engine oil cooler to start with. Fun job any one else see this problem. Funny the trans is low and the engine oil level is down slightly. Its not red in the degas bottle so I am going after the engine oil cooler. /forums/images/%%GRAEMLIN_URL%%/banghead.gif Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted December 30, 2004 Share Posted December 30, 2004 Here's a thought: Have you installed UV dye in the engine oil and tried to detect it in the coolant de-gas bottle? As far as changing the oil cooler it's really not that bad of a job on a 6L PSD. I think I would prefer it to the 7.3L PSD because it's right up on top. Quote Link to comment Share on other sites More sharing options...
Kyle Posted December 30, 2004 Share Posted December 30, 2004 i havent seen this on a 6.0 but replaced my share on the 7.3 for the same complaint Quote Link to comment Share on other sites More sharing options...
FordMastertech Posted December 31, 2004 Author Share Posted December 31, 2004 Yea, I did the dye test first on the engine and then on the transmission. Nothing showed up on either test. Kyle, Same here for the old tried and true 7.3. Boy I sure miss those engines for the ease of diag and repair. /forums/images/%%GRAEMLIN_URL%%/notworthy.gif Quote Link to comment Share on other sites More sharing options...
DieselDan Posted January 4, 2005 Share Posted January 4, 2005 Did the cooler fix it? /forums/images/%%GRAEMLIN_URL%%/shrug.gif Quote Link to comment Share on other sites More sharing options...
Dzltech Posted January 7, 2005 Share Posted January 7, 2005 Did you check for combustion gases in bottle?? Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted January 8, 2005 Share Posted January 8, 2005 Quote: Did you check for combustion gases in bottle?? dzltech, how do you check for combustion gasses in the cooling system? Other than odor and using a pressure tester the only other way I know of is to use a Co2 sniffer which I do have but I am not sure that it works with the diesels. (I have yet to test positive) Quote Link to comment Share on other sites More sharing options...
FordMastertech Posted January 8, 2005 Author Share Posted January 8, 2005 quote: Originally posted by DieselDan: Did the cooler fix it? /forums/images/%%GRAEMLIN_URL%%/notworthy.gif Quote Link to comment Share on other sites More sharing options...
CERTIFIEDFORDTEC Posted June 27, 2005 Share Posted June 27, 2005 what else did you replace with the oil cooler. i got one on order right now on a 04 f550. i order the cooler and hoses and of course the cascade.i thought i'd try some moc coolant flush stuff too! Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted June 28, 2005 Share Posted June 28, 2005 The degas bottle can be a PITA to get clean, I usually replace that. There's a TSB that says that flushing it twice will do the trick... I'd like some of what they're smoking. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted June 28, 2005 Share Posted June 28, 2005 I just tried the search function for the first time and it worked well /forums/images/%%GRAEMLIN_URL%%/wink.gif wink! wink! Heres a post that might help ya! Oil Cooler #3 I haven't had any bad oil coolers on the 6.0L but some of the guys in that thread may have some advice for you. Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted June 28, 2005 Share Posted June 28, 2005 Oddball service tip... I used one of the jacking beams on my 4 poster to lift the exhaust downpipe out of the way. You would not believe the amount of room this opens up for intake installation and EGR cooler hook-up. Quote Link to comment Share on other sites More sharing options...
