skidoo700 Posted February 27, 2008 Share Posted February 27, 2008 Any tricks for getting oil and EGR coolers on E450? I always seem to come up short. Warranty time is 8.2 for the coolers and 2.2 for all the extra coolant tests. How long is this job taking others out there. Quote Link to comment Share on other sites More sharing options...
Tony302600 Posted February 27, 2008 Share Posted February 27, 2008 meh.....my first one was an ambulance....got a hella lot of m-time. The other one i was doing an engine harness in, and noticed milky stuff in the upper radiator hose...so i swapped it out. DUAL ALTERNATORS SUCK!!!! If its a work van /forums/images/%%GRAEMLIN_URL%%/thumbup.gif easy....if its got all those stupid coolant hoses and a/c line for rear air...then it gets a little harder IMHO. Day and a half if you take ure time and make sure ure doing it right. Quote Link to comment Share on other sites More sharing options...
Mekanik Posted February 28, 2008 Share Posted February 28, 2008 I have done 2 in econolines. 1 was an ambulance, and the other was a little bus. I would say probably 12-14 hours. If it is just a redular van consider yourself lucky!!! Quote Link to comment Share on other sites More sharing options...
mchan68 Posted February 28, 2008 Share Posted February 28, 2008 I have done more than my share on E-450s. Remove the three heat exchangers (CAC, A/C condensor, and radiator) as one assembly. Remove the top rad support crossmember to make working in the area more comfortable. Those are my /forums/images/%%GRAEMLIN_URL%%/2cents.gif Quote Link to comment Share on other sites More sharing options...
