Jwebb1981 Posted February 29, 2008 Share Posted February 29, 2008 Our dealership just bought a 05 f650 rollback with a cat. It ran out of fuel on the way home the other night, but the real fuel tank is full. How does the transfer system work? Is there a switch or something? Does the computer run it? please help! Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted February 29, 2008 Share Posted February 29, 2008 You should check OASIS. See TSB 07-21-1 DUAL FUEL TANK - ONE EMPTY - FUEL DOES NOT TRANSFER The dual tank system uses a fuel tank transfer pump that relies on both fuel level sensors to operate correctly. Fuel is draw from the right side tank only and as the transfer pump reads the level dropping in the tight tank, it pumps fuel from the left tank to even the levels. The TSB diagnostics are easy. I have replaced quite a few sending units... there is a revised part. I have only seen two bad transfer pumps. Also, see THIS TOPIC for another discussion on this concern. Quote Link to comment Share on other sites More sharing options...
eastendpowerstroke Posted March 1, 2008 Share Posted March 1, 2008 You should check OASIS. See TSB 07-21-1 DUAL FUEL TANK - ONE EMPTY - FUEL DOES NOT TRANSFER The dual tank system uses a fuel tank transfer pump that relies on both fuel level sensors to operate correctly. Fuel is draw from the right side tank only and as the transfer pump reads the level dropping in the tight tank, it pumps fuel from the left tank to even the levels. The TSB diagnostics are easy. I have replaced quite a few sending units... there is a revised part. I have only seen two bad transfer pumps. Also, see THIS TOPIC for another discussion on this concern. +1 for the senders but I have also seen a lot of failed transfer pumps. If you find that the plastic top of the sender/senders is white save your self the trouble replace BOTH senders the revised have a black top. Quote Link to comment Share on other sites More sharing options...
