7.3L no mid throttle
Any one ever seen this weard problem ? 00 F-350 CREW CAB DRW 6-SPEED 4X4 76k. when driving mid throttle 3rd gear & up cruising you go to push on throttle it hits a dead spot if continue to push acc pedal it pick's up & goes put you can hold it at this spot & it wont acclerate hot cold no diff. i can say its not a turbo not a fuel filter .no ex restriction ,pcm new, stock power same as with extra power added new accl pedal updates new any ideas ?
