Jeff_ Posted March 5, 2008 Share Posted March 5, 2008 I thought you guys might want to know about this in case you ever run into one. This Truck was towed in with dead batteries due to a no charging concern and the cluster was also dead. found the cluster fuse which happened to be #45 in the CJB on this truck was blown, and would blow intermittently during parking maneuvers. The usual chafe points were ok, but upon further digging I found the Tow Haul switch wiring was rubbing on the shifter mechanism. Wiring repair fixed both concerns. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted March 5, 2008 Share Posted March 5, 2008 I am not knocking you at all. But wow. That wire chafe has been a problem ever since the early 1990's and the E4OD first came out. Anyway, good find if you have never seen this before. I went looking for TSB on this because I was sure there was one... I cant find one! I would have thought that one would have been issued considering the number of trucks that had this happen. I know I have done several dozen over the years. Maybe it was just a Special Service Message... you know, that valuable information that disappears? /forums/images/%%GRAEMLIN_URL%%/rolleyes.gif Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted March 6, 2008 Share Posted March 6, 2008 I don't recall that ever being a message... but it probably should have been, seeing how common it was, and still is... Quote Link to comment Share on other sites More sharing options...
Tony302600 Posted March 6, 2008 Share Posted March 6, 2008 OMG, i love that wire chafe... I remember my first one...i was driving 01 7.3L F-550 ( customer was complaining of a bearing noise ) and the truck lost pedal, cluster all that major stuff on the CKT but still idled. I sat there like.... WTF. Then came back to the shop and figured it out. I had one on a 04F-350 with a 6.0 and torqshift in it also. Quote Link to comment Share on other sites More sharing options...
