kellyf Posted March 5, 2008 Share Posted March 5, 2008 have a 2000 f-350 with a skip when first accelerating,or in between changing gears.ran thru test and found #3 cyl not contributing.replaced that cyls injector.Now truck runs worst than ever.reran test.Now have 3 and 8 cyl failing.what am I missing? Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted March 5, 2008 Share Posted March 5, 2008 Did you take it for a good hard romp to make sure that you've blown all the air out of the high pressure system? Quote Link to comment Share on other sites More sharing options...
kellyf Posted March 5, 2008 Author Share Posted March 5, 2008 Yes.When I view percent delta on cyls 3 and 8 it is around 2.It shows no percent on other cylinders. Quote Link to comment Share on other sites More sharing options...
Shlep Posted March 6, 2008 Share Posted March 6, 2008 What did the o-rings look like on the injector that you replaced? Quote Link to comment Share on other sites More sharing options...
Mekanik Posted March 6, 2008 Share Posted March 6, 2008 Stupid question, but I have to ask. Are you sure it was the correct injector for this truck. It wasn't a cyl. #8 injector was it? Quote Link to comment Share on other sites More sharing options...
kellyf Posted March 6, 2008 Author Share Posted March 6, 2008 The o-rings looked good.The injector cup looked good. Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted March 6, 2008 Share Posted March 6, 2008 How many miles on the engine? Any signs of carbon, like combustion blow by or contamination? Could be domino effect in the system. Or could just be time to replace the set. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted March 6, 2008 Share Posted March 6, 2008 The o-rings looked good.The injector cup looked good. I've PLENTY of both of those that looked fine visually and leaked. Buzz test good? Fill the FF with Stanadyne and see how it runs. If it's better, it's either bad fuel or bad injectors. Like Larry said, most of these need a set when they need one. /forums/images/%%GRAEMLIN_URL%%/grin.gif Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted March 6, 2008 Share Posted March 6, 2008 Like Larry said, most of these need a set when they need one. You ain't kidding! I have been bitten a few times in the past by bad sets of injectors. Get a truck in running very poorly, missing hard on one or more cylinders - replace the flagged offenders only to have more from the bunch begin to drop out. All of those turned out to have had low fuel pressure and fuel quality issues (rusted fuel tanks) It's no fun accessing injectors three times only to realize the whole set was shot. Quote Link to comment Share on other sites More sharing options...
kellyf Posted March 6, 2008 Author Share Posted March 6, 2008 Is it possible since 3 and 8 are opposing cylinders that this may be throwing off my test? Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted March 6, 2008 Share Posted March 6, 2008 Is it possible since 3 and 8 are opposing cylinders that this may be throwing off my test? Yes, since PERDELS and CC are relative tests, if you start with 6 weak cyls and 2 really weak cyls, you put in 2 new injectors in the really weak cyls, the 6 weak cyls all of the sudden come into the limelight. To rephrase another way, if you have 6 pulling at 70% and 2 pulling at 50%, the two at 50% get changed. Then the 6 at 70% all look really bad compared to the 2 new ones pulling 100%. Kind like a slacker shop that hires a whiz bang tech. He can make the others look bad..... /forums/images/%%GRAEMLIN_URL%%/grin.gif Quote Link to comment Share on other sites More sharing options...
kellyf Posted March 12, 2008 Author Share Posted March 12, 2008 Just wanted everyone to know that this was caused by a bum cam sensor that installed two weeks ago.After contacting hotline for third time,get someone that says"Has this thing had a cam sensor installed?"Seems some new sensors throw off the signal to pcm causing for corrections that don't need to be made.Hope this helps some other poor sucker.Thanks Ford! Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted March 12, 2008 Share Posted March 12, 2008 Now, recal 07S57 was supposed to correct/prevent what? /forums/images/%%GRAEMLIN_URL%%/banghead.gif Quote Link to comment Share on other sites More sharing options...
jaysonfordtech Posted March 14, 2008 Share Posted March 14, 2008 Oh ya we got the same info from hotline. It may cause some problems, but its only $20. What a deal. Quote Link to comment Share on other sites More sharing options...
