BrunoWilimek Posted March 6, 2008 Share Posted March 6, 2008 Our parts man asked me if the intake manifold from a 7.3 IDI would retrofit to a 6.9 IDI. Apparently the gasket is the same. This question came from a customer. I don't have a lot of 6.9 and 7.3 IDI experience. /forums/images/%%GRAEMLIN_URL%%/shrug.gif Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted March 7, 2008 Share Posted March 7, 2008 I probably knew the answer to this question many years ago but have dumped that cache to make room for newer stuff. Let's assume these are both Fords, because I know the intakes were different between the IH version and the Ford version. Another minor problem might be the glow plug system- the 7.3 probably has the later bullet system and the 6.9 probably has the blade style system. I know when retrofitting a truck to the bullet system I have to drill a hole or something back there to mount the controller. There was some kind of difference in the intake ports- later engines had a passageway that was plugged with a ball just under the port (or something like that). Just because the gaskets are (supposedly) the same doesn't meant the intakes interchange, even at the port flange. Think as hard as I might, I still can't answer this for sure. Man, if I had a penny for every one of those I had apart..... /forums/images/%%GRAEMLIN_URL%%/grin.gif Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted March 7, 2008 Share Posted March 7, 2008 I probably knew the answer to this question many years ago /forums/images/%%GRAEMLIN_URL%%/grin.gif Bruce has CRS... Bruce has CRS... Welcome to the club!!!! It's all downhill from here..... Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted March 7, 2008 Share Posted March 7, 2008 The 6.9 and 7.3 IDI do use the same gasket, but I'm not sure if the intake is the same. The customer should check the #'s on the manifold and lay them side by side to be sure. Quote Link to comment Share on other sites More sharing options...
BrunoWilimek Posted March 7, 2008 Author Share Posted March 7, 2008 Thanks. guys for your quick responses. That is about what I suspected. I don't know why he wants to do this swap other than he has a complete 7.3 and the truck has a 6.9 in it, but I try to keep our customers happy. /forums/images/%%GRAEMLIN_URL%%/notworthy.gif Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted March 8, 2008 Share Posted March 8, 2008 Bruno, today I laid out 2 intakes side by side, it looks like they are the same between the 6.9 and 7.3 IDI. My bad but didn't grab the #'s off of them. Will look at them monday and let you know for sure. I believe that the early IDI's are pretty close to each other, other than the bore, correct me if I'm wrong( I know Jim will ). By the way Bruce is suffering from SOMETIMERS Quote Link to comment Share on other sites More sharing options...
BrunoWilimek Posted March 10, 2008 Author Share Posted March 10, 2008 Thanks. I wondered if maybe the ports were larger on the 7.3, but numbers would tell us if the casting was the same. Quote Link to comment Share on other sites More sharing options...
