Huge Brainfart
Ok, early 03, missing, smokes ALOT... #1 injector failed. Replaced #1 injector, test drove, started running rough, checked power balance, #6 was at +40%, and the rest of the injector's were at -20%. Throwing codes for # 6 contribution. Fuel is at 47psi (awesome).
Here's my brainfart....#6 at +40% throwing a contribution code for #6.
So +40% means the injector is overfueling that cylinder, causing all my smoke? I'm soo drained with 6.0L stuff lately.
Geez, the first time I read this post I thought we were talking about a gas engine.
Yes, I'd say #6 is overfueling. Compression test passes? Does your smoke go away when you disable #6? Can you correlate smoke diminishing when you kill any injectors?
