kevin phillips Posted April 5, 2008 Share Posted April 5, 2008 have a 08 f350 6.4 liter popping through intake on decel kinda like a 6.0 does with a stuck unison ring,no codes any ideas on the problem.Vehicle has 34000 miles and just started doing it.i'm new to the 6.4 and lost on where to go.thanks for any ideas and help Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted April 5, 2008 Share Posted April 5, 2008 Check your DPF regeneration PID. If it is regenerating (active), it's normal. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted April 5, 2008 Share Posted April 5, 2008 Yes... I recall noticing that a 6.4L during regen will make a turbo flutter sound similar to the 6.0L during sudden deceleration. Good call Alex! Quote Link to comment Share on other sites More sharing options...
kevin phillips Posted April 6, 2008 Author Share Posted April 6, 2008 i'll check that monday,see if it's in regen and update Quote Link to comment Share on other sites More sharing options...
Alex Bruene Posted April 7, 2008 Share Posted April 7, 2008 Or have a look at TSB 07-04-11. It will give you characteristics to help you determine if it is regenerating without having to hook up your IDS. Quote Link to comment Share on other sites More sharing options...
kevin phillips Posted April 9, 2008 Author Share Posted April 9, 2008 used the tsb for help,was doing a regen and was normal for the vehicle thanks guys Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted June 30, 2008 Share Posted June 30, 2008 I thought I'd resurrect this post to show you guys something wonderful. The brand new 6.4 reflash finally has an indicator in the dash to let the customer know when they are in regen!!!! /forums/images/%%GRAEMLIN_URL%%/cheers.gif /forums/images/%%GRAEMLIN_URL%%/notworthy.gif /forums/images/%%GRAEMLIN_URL%%/rockon.gif /forums/images/%%GRAEMLIN_URL%%/cheers.gif Quote Link to comment Share on other sites More sharing options...
