P1502 (APCM Functioning)
Vehicles: Multiple E model ambulances from 04-06.
Complaint: Will not run KOER with P1502 setting
Code Description: Invalid test, APCM functioning
Fault Trigger/Comments: Aborts test, KOER, CCT, Switch Test
Probable Cause: APCM active while test is running
This fleet of ambulances will not run the KOER. The trouble is, we could not find APCM's mounted anywhere, the techs state they did away with APCM's and hard wired the circuit into the ambulance package.
I did this class last week and 3 units would not run the KOER.
Sooo, is the APCM hidden away in never never land, or is it really hard wired in? If it is hard wired in, how would we disconnect it or enable the KOER?
I can't believe how many million miles these units have run with nobody running a KOER. /forums/images/%%GRAEMLIN_URL%%/frown.gif
Has anyone seen this before?
Thanks!
bruce been through this many times. The ambulance manufacturers use the pto wiring under the hood next to the booster for idle/charge controls. one of those wires is for pto enable and they apply ignition voltage to that wire so the pcm always thinks its in pto and waiting for the parking brake to complete the function. a temporary fix is to cut that wire and run the koer test and repair it when done or just add a relay to connect it for you wuth a trigger from the park wire located in the same area.i can send you a schematic i made tomorrow if you like.
Anthony and Dwayne:
Thanks very much for the great info, I will forward it to the fleet and see if it helps. Thanks for the phone call yesterday too, Anthony. I know it is many times easier to explain things over the phone than type out a huge response.
Have a great week!
