ktmlew Posted April 30, 2008 Share Posted April 30, 2008 Need the arm that connects to the pushrod, bushing that goes in pushrod & attaching hardware for two different trucks. Probably should get the pushrod too? Mainly looking for part numbers as getting SuperDuty or Diesel parts here is a little sketchy...might be same part number for both? 96 F-250 7.3L PS 93 F-450 7.3 IDI Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted April 30, 2008 Share Posted April 30, 2008 Same part # for both E7TZ7A554A Detroit PDC shows well over a hundred in stock. Quote Link to comment Share on other sites More sharing options...
ktmlew Posted April 30, 2008 Author Share Posted April 30, 2008 OK Thanks! I thought the arm might be the same. Local dealer has the arm & retaining clip but the pushrod is not available seperate from M/C. Less than $40.00 worth of parts will make it easier to get in gear and so you don't have to push the pedal through the floor to activate the safety switch! /forums/images/%%GRAEMLIN_URL%%/thumbup.gif Quote Link to comment Share on other sites More sharing options...
LARRY BRUDZYNSKI Posted April 30, 2008 Share Posted April 30, 2008 When you get the new arm don't freak out, it's fairly soft metal and does not have the serations in the hole, they are made when you attach the new arm and tighten down the nut. Quote Link to comment Share on other sites More sharing options...
ktmlew Posted April 30, 2008 Author Share Posted April 30, 2008 When you get the new arm don't freak out, it's fairly soft metal and does not have the serations in the hole, they are made when you attach the new arm and tighten down the nut. Yep. BTDT before. I had forgotten how hard they are to get off though...my back wasn't great today BEFORE I did this job...actually may feel better after? /forums/images/%%GRAEMLIN_URL%%/rockon.gif Quote Link to comment Share on other sites More sharing options...
