kevin phillips Posted May 20, 2008 Share Posted May 20, 2008 went to order tools for tsb 08-11-3 and wanted to order the blockoffs for the egr cooler which showed up and i ordered.having trouble finding 014-00761 adapter and 014-00761 pressure tester.anyone have the correct tool numbers that will work to order this stuff.those numbers off the tsb are not working on rotunda's site.thanks for any info Quote Link to comment Share on other sites More sharing options...
BrunoWilimek Posted May 20, 2008 Share Posted May 20, 2008 014-00761 changes up to the new global number of 303-F021. I found it at the very bottom of page 273 in our 2007 Rotunda catalog. Quote Link to comment Share on other sites More sharing options...
kevin phillips Posted May 20, 2008 Author Share Posted May 20, 2008 014-r1068 is the adaptor number listed in the tsband it won't cross either on the site. thanks for the other global number Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted May 21, 2008 Share Posted May 21, 2008 Quote: Road Test Setup And Observations: Install the IDS PVT, or Rotunda Pressure Adapter Kit 014-00761, or equivalent. (Figure 4) - Article 08-11-3 I think 014-00761 is just a regular cooling system pressure tester which is why they say "or equivalent" I've always used my Matco one without any problems for that test, I just pull the radiator adapter off of it and hook up the rubber hose of my tester to the cooling system nipple to monitor actual cooling system pressure under load. Check your tool room for the 3 red boxes labeled "TKIT-2006SD-FLM 6.4L" The egr cooler test plates are in one of those. They are not just for the 6.4, they work equally well on the sicko. If you don't have the 6.4 tool kits, the tool number to order the EGR cooler test plate set is: 303-1268 and dealer cost is $51.40 plus tax and shipping. Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted May 21, 2008 Share Posted May 21, 2008 Kevin, you might want to check real close in your tool room. We received the 6.0 test plates as a drop ship item back in 2003/2004. Quote Link to comment Share on other sites More sharing options...
OHNO60 Posted May 21, 2008 Share Posted May 21, 2008 Yup your right Jim! as a matter of fact we had "lost" a set of them and found it cheaper to order them through International. Quote Link to comment Share on other sites More sharing options...
Tony302600 Posted May 21, 2008 Share Posted May 21, 2008 SO the 6.4L ones work? Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted May 21, 2008 Share Posted May 21, 2008 Quote: Rotunda Cross Reference Search Enter Current Number, Past Number, Description of a tool or enter a TKit name. TKit(s) that tool 303-1268 is in. TKIT-2006SD-F 1 tool(s) matching '303-1268' Current Tool Number Past Tool Number Description 303-1268 303-1268 EGR COOLER TEST PLATES Yes they work, and according to my Rotunda cross reference search, the 6.0 and 6.4 egr cooler test plates are the same tool, and are found in the 6.4 TKIT Quote Link to comment Share on other sites More sharing options...
kevin phillips Posted May 21, 2008 Author Share Posted May 21, 2008 thanks guys the 6.4 plates work.i never knew they were the same parts and our tools are terrible far as finding them.this dealer i'm at started in 1913 and all the tools since then are in a 10 foot square room. it's hell finding anything. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted May 21, 2008 Share Posted May 21, 2008 Ya'll work off a dirt floor? /forums/images/%%GRAEMLIN_URL%%/smile.gif Quote Link to comment Share on other sites More sharing options...
eastendpowerstroke Posted May 21, 2008 Share Posted May 21, 2008 Brad you live way way to far north to use the word "ya'll" without being thrown a beating /forums/images/%%GRAEMLIN_URL%%/boxing.gif, even if your trying to tease a TAR HEEL /forums/images/%%GRAEMLIN_URL%%/poke.gif Quote Link to comment Share on other sites More sharing options...
kevin phillips Posted May 21, 2008 Author Share Posted May 21, 2008 pretty close,it's been by the same family since the beginning.we still have the old twin post underground lifts with rear and front on seperate controls in most of the bays.it's had a few facelifts but it was the first ford dealer in nc.they don't buy any tools much but we improvise if we need to.i've been working on talking them into some new stuff but it's hard to do when for so long they have had so little far as extra stuff. Quote Link to comment Share on other sites More sharing options...
kevin phillips Posted May 21, 2008 Author Share Posted May 21, 2008 youwanto,is a word down here lol.my internet connection was barbed wire last time i checked but it works. Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted May 22, 2008 Share Posted May 22, 2008 /forums/images/%%GRAEMLIN_URL%%/rofl.gif Don't let the location fool ya, I'm originally from Anderson South Carolina. Home of the Clemson Tigers! Quote Link to comment Share on other sites More sharing options...
