dt466e torque specs
Injector hold downs, 120 in/lb. Valve cover, 13 ft/lb. Adjust the valves while you're in there, as they will be loose and the guy will feel the power when they're set right.
Valve lash, .025 cold in/ex.
Thanks Bruce, I set the valve like you said and got it back together, wow what a difference. The customer even said it sounded like it idled alot better.
Thanks agian for the help. /forums/images/%%GRAEMLIN_URL%%/smile.gif
