Keith Browning Posted August 4, 2008 Share Posted August 4, 2008 2008 Truck & Diesel SSMs 1802 - 2008 - 2009 5R110W COLD WEATHER TRANSMISSION FAILURE IN VEHICLES BUILT BETWEEN 5/18/2007 AND 11/1/2008 SEE TSB 08-26-04 FOR DETAIL 08-26-04 1801 - DRIVEABILITY - NO START, HARD START, RUNS ROUGH - FUEL INJECTION CONTROL MODULE DIAGNOSIS - 6.0L DIESEL SEE TSB 08-26-03 FOR DETAIL 08-26-03 1800 - VEHICLES EQUIPPED WITH THE TIRE PRESSURE MONITORING SYSTEM SWAPPING WHEELS ON 2009 VEHICLES WITHOUT RETRAINING THE TIRE PRESSURE MONITORING SYSTEM (TPMS) SENSORS TO THE VEHICLE MODULE WILL SET A TPMS FAULT. REFER TO TPMS SENSOR TRAINING IN SECTION 204-02 WHEELS AND TIRES IN THE SERVICE MANUAL OR REFER TO THE SERVICE TIP TPMS SENSOR TRAINING ON THE PTS WEBSITE. 1797 - 2008 F-SUPER DUTY GASOLINE ENGINES WITH DTC P0111 SOME 2008 MODEL YEAR F250-550 SUPER-DUTIES EQUIPPED WITH 5.4L 3-VALVE OR 6.8L-3V ENGINES MAY EXHIBIT MIL AND DIAGNOSTIC TROUBLE CODE(DTC) P0111 INTAKE AIR TEMPERATURE(IAT) SENSOR 1 CIRCUIT RANGE/PERFORMANCE DURING COLD AMBIENT TEMPERATURES WITH UTILIZATION OF A BLOCK HEATER. IF NORMAL PCED DIAGNOSTIC PROCEDURES DO NOT RESOLVE VEHICLE CONCERN DO NOT ATTEMPT FURTHER REPAIRS. CONFIRM WITH CUSTOMER THAT THIS CONDITION ONLY OCCURS WHEN THE ENGINE BLOCK HEATER IS USED AS REPLACEMENT OF SENSORS AND COMPONENTS WILL NOT RESOLVE. ENGINEERING IS CURRENTLY INVESTIGATING. MONITOR OASIS FOR UPDATES. 1795 - 2009 F-SUPER DUTY 6.4L DRW AND 6.8L DRW - 2" HITCH ADAPTER AND PIN NO LONGER INCLUDED WITH 15K BUILT FORD TOUGH TRAILER HITCH RECEIVER IN PRODUCTION 2009 F-SUPER DUTY VEHICLES EQUIPPED WITH 6.4L DUAL REAR WHEELS (DRW) OR 6.8L DRW NO LONGER INCLUDES THE 2" HITCH ADAPTER AND PIN FOR THE 2 1/2" OR 15K BUILT FORD TOUGH TRAILER HITCH RECEIVER. DO NOT INSTALL THE 2" HITCH ADAPTER (P/N 5C3Z 19H282 AB) OR PIN KIT (P/N 5C3Z 19A326 A), AS THIS IS NO LONGER A PART OF THE TRAILER HITCH PACKAGE AND IS A NON-WARRANTABLE ITEM. THE 2" HITCH ADAPTER AND PIN KIT ARE STILL AVAILABLE TO THE CUSTOMER THROUGH FORD PARTS AND SERVICES. 1790 - 2008-2009 F-SUPER DUTY 650/750 - CATERPILLAR - SERVICE ENGINE SOON LAMP FLASHING REGENERATION (DPF) - BUILT ON OR BEFORE 6/26/2008 SEE TSB 08-26-01 FOR DETAIL 08-26-01 1788 - IDS REQUIREMENTS FOR SYNC 911 ASSIST AND VEHICLE HEALTH REPORT (VHR) SERVICE TIP - VEHICLES EQUIPPED WITH SYNC 911 ASSIST™ AND VEHICLE HEALTH REPORT (VHR) SERVICES OR THAT HAVE BEEN UPGRADED TO ACTIVATE THESE SERVICES, WILL REQUIRE IDS/PDS VERSION B58 OR HIGHER TO PROPERLY DIAGNOSE OR COMMUNICATE WITH THE SYNC (APIM) MODULE. IF IDS/PDS VERSION B58 OR HIGHER IS NOT INSTALLED IDS/PDS WILL FAIL TO COMMUNICATE WITH THE SYNC (APIM) MODULE. IDS/PDS VERSION B58 SHOULD BE AVAILABLE IN DEALERS BY 12/1/08. 1787 - 2009 F-SUPER DUTY 650/750 -REVISED BLEED PROCEDURE MERITOR WABCO SYSTEM - BRAKE WARNING LIGHT AND/OR ABS LIGHT ON DTCS - SID 57 FMI 10 AND/OR SID 60 FMI 10 SEE TSB 08-25-11 FOR DETAIL 08-25-11 1783 - 2009 F-SUPER DUTY - 6.4L - VEHICLES BUILT PRIOR TO 12/1/2008 - DIESEL CALIBRATION UPDATES SEE TSB 08-25-10 FOR DETAIL 08-25-10 1782 - 2008 F-SUPER DUTY - 6.4L - VEHICLES BUILT BETWEEN 1/3/2008 AND 9/15/2008- DIAGNOSTIC TROUBLE CODES P0128, P0196, P1335, P0404, P0406, P246C AND P2463 SEE TSB 08-25-09 FOR DETAIL 08-25-09 1781 - 2008 F-SUPER DUTY - 6.4L - VEHICLES BUILT BETWEEN 8/3/2007 AND 1/2/2008 - MODULE REPROGRAMMING SEE TSB 08-25-08 FOR DETAIL 08-25-08 1780 - 2008 F-SUPER DUTY - 6.4L - VEHICLES BUILT PRIOR TO 8/2/2007 - MODULE REPROGRAMMING SEE TSB 08-25-07 FOR DETAIL 08-25-07 1743 - 2008-2009 F-SUPER DUTY 250-550 - 6.4L DIESEL - WHITE SMOKE IN DAMP WEATHER CONDITIONS WHEN ACCELERATING - VEHICLES BUILT BEFORE 10/1/2008 SEE TSB 08-25-01 FOR DETAIL 08-25-01 1742 - 2004-2008 MULTIPLE VEHICLES - CIGAR LIGHTER / POWER POINT FUSE REPLACEMENTS CUSTOMERS SHOULD BE ADVISED THAT ANY AFTER MARKET DEVICE PLUGGED INTO THE CIGAR LIGHTER / POWER POINT THAT CREATES AN OVER CURRENT CONDITION EXCEEDING THE 12VDC (180W/20A) RATING AND CAUSING THE 20A FUSE TO BLOW, IS NOT COVERED UNDER THE VEHICLE WARRANTY. POWER POINT / CIGAR LIGHTER SOCKETS HAVE A LOAD CAPACITY NOT TO EXCEED 12VDC/180W (20AMP). REPAIRS ARE NOT REIMBURSABLE UNDER WARRANTY IF 1) CUSTOMER USE OF THE POWER POINT(S) / CIGAR LIGHTER EXCEEDS THE 12VDC/180W (20AMP) RATING OF THE CIRCUIT AND CAUSES THE FUSE TO BLOW AS DESIGNED. 2) ALTERATION OR MODIFICATION OF THE VEHICLES ELECTRICAL SYSTEM AFTER THE VEHICLE LEAVES FORDS CONTROL. FUSE REPLACEMENT DUE TO OVERLOADING OF THE CIRCUIT BY THE CUSTOMER IS NOT A WARRANTABLE REPAIR. 1741 - CATERPILLAR - LOWER RADIATOR HOSE CHAFFE SEE TSB 08-24-11 FOR DETAIL 08-24-11 1735 - 2005-2009 EXPEDITION/NAVIGATOR, 2005-2008 F-150, F250-F550 AND 2006-2008 MARK LT - WATER LEAKS AT ROOF OPENING PANEL DURING HIGH PRESSURE CAR WASH SEE TSB 08-24-08 FOR DETAIL 08-24-08 1731 - 2008 - 2009 F-SUPER DUTY - 6.4L DIESEL COOLANT FILL 6.4L DI WITH TWO VENT PORT DEGAS BOTTLE COOLANT FILL (WSM RADKITPLUS PROCEDURE RECOMMENDED). WSM FILL AND BLEED WITHOUT RADKITPLUS PROCEDURE BEING UPDATED TO: 1)WITH ENGINE OFF, FILL DEGAS BOTTLE TO BOTTOM OF FILLER NECK. 2)START ENGINE AND IDLE FOR 2 MINUTES. 3)REFILL TO THE BOTTOM OF FILLER NECK. 4)RUN ENGINE AT 2000 RPM FOR 5 MINUTES. 5)REFILL TO BOTTOM OF FILLER NECK. 6)INSTALL DEGAS BOTTLE CAP. NOTE, DRIVING VEHICLE FOR APPROX 5 MILES SHOULD DROP COOLANT TO PROPER LEVEL IN DEGAS BOTTLE. WSM COOLANT LEVEL CHECK BEING UPDATED TO:1)COOL ENGINE COOLANT LEVEL SHOULD BE WITHIN COLD FILL RANGE OF DEGAS BOTTLE. 2)WARMED ENGINE AS INDICATED BY THE TEMPERATURE GAUGE READING IN MIDDLE OF NORMAL RANGE, COOLANT LEVEL SHOULD BE 10-20MM ABOVE TOP OF COLD FILL RANGE IF DEGAS CAP IS INSTALLED AND 20 30MM ABOVE TOP OF COLD FILL RANGE IF DEGAS CAP IS REMOVED. 1728 - 2007-2009 MODEL YEAR GAS ENGINE VEHICLES - HIGHER THAN NORMAL IDLE SPEEDS SOME 2007-2009 MODEL YEAR VEHICLES EQUIPPED WITH A GAS ENGINE, WITH LESS THAN 50 TOTAL STARTS, OR LESS THAN 5 CONTINUOUS MILES OF DRIVING BETWEEN STARTS, MAY EXHIBIT HIGHER THAN NORMAL ENGINE IDLE SPEEDS. PLEASE INFORM THE CUSTOMER THIS IS A NORMAL CHARACTERISTIC. SERVICE SHOULD NOT ATTEMPT REPAIR. AFTER 5 CONSECUTIVE MILES OR 50 STARTS, THE IDLE SHOULD RETURN TO NORMAL. 1724 - 2008-2009 F-SUPER DUTY 250/350 SINGLE REAR WHEEL (SRW) - SHUDDER/VIBRATION ON ACCELERATION (ESPECIALLY WHEN LOADED) SEE TSB 08-24-06 FOR DETAIL 08-24-06 1720 - 1999-2009 MULTIPLE VEHICLES - FLUTTER/TURBULENCE NOISE AT HIGHWAY SPEEDS WITH REAR WINDOWS OR MOON/SUN ROOF OPEN SOME 1999-2009 VEHICLES MAY EXHIBIT A FLUTTER/TURBULENCE NOISE (HELICOPTER NOISE) AT HIGHWAY SPEEDS WHEN THE REAR DOOR WINDOW(S) OR SUN/MOON ROOF ARE OPEN. THIS CONDITION IS A CHARACTERISTIC OF THE VEHICLE BODY DESIGN AND IS ALSO A CHARACTERISTIC OF COMPETITIVE VEHICLES WITH A SIMILAR BODY STYLE. THIS CONDITION CAN BE REDUCED BY LOWERING EITHER ONE, OR BOTH, OF THE FRONT WINDOWS AT LEAST 2 INCHES. NO SERVICE ACTION IS RECOMMENDED FOR THIS CONDITION. 1715 - DIAGNOSTICS FOR A VEHICLE THAT HAS NO START/NO COMMUNICATION WITH THE PCM WHEN PERFORMING DIAGNOSTICS FOR A VEHICLE THAT HAS NO START/NO COMMUNICATION WITH THE PCM, IDS MAY DISPLAY THE MESSAGE 'THE PCM IS BLANK'. PRIOR TO PCM REPLACEMENT, VISUALLY INSPECT FUSES FOR THE PCM. BACK FEED THROUGH THE PCM CAN ILLUMINATE A TEST LIGHT ON BOTH SIDES OF AN OPEN FUSE. VALIDATE POWERS AND GROUNDS TO THE PCM LOAD TESTED AND VOLTAGE DROPPED. REFER TO PC/ED PINPOINT TEST QA1, UNABLE TO ACTIVATE SELF-TEST/NETWORK COMMUNICATION ERROR, FOR ADDITIONAL DIAGNOSTICS. 1686 - ANNOUNCING TWO NEW DIESEL COOLANT FLUSH PROCEDURES THERE ARE NOW TWO NEW DIESEL COOLING SYSTEM FLUSH PROCEDURES. TSB 08-23-1, TO BE USED IF THE COOLING SYSTEM IS CONTAMINATED (WITH OIL, FUEL OR TRANS. FLUID) AND A NEW UNIQUE DIESEL COOLING SYSTEM FLUSH PROCEDURE LOCATED IN THE ONLINE WSM, SECTION 303-03. THE FINAL STEPS IN BOTH PROCEDURES REQUIRE THE USE OF MOTORCRAFT ENGINE COOLING SYSTEM IRON CLEANER (VC-9), TO ENSURE THAT THE COOLING SYSTEM IS FREE OF RUST. ALL STEPS MUST BE COMPLETED IN ORDER TO PROPERLY CLEAN THE COOLING THE COOLING SYSTEM. ANY DEVIATION FROM THESE SERVICE PROCEDURES WILL RESULT IN SHORTENED COOLANT PROTECTION AGAINST CORROSION IN THE COOLING SYSTEM. 1665 - 2008 - 2009 F-SUPER DUTY - 6.4L DIESEL ENGINE OIL LEVEL DIAGNOSTIC AID ON 6.4L ENGINES, TO PREVENT SERIOUS ENGINE DAMAGE IT IS CRITICAL TO ACCURATELY MEASURE ENGINE OIL LEVELS DURING VEHICLE DIAGNOSTICS. TO PROPERLY DETERMINE ENGINE OIL LEVEL, THE ENGINE MUST BE AT NORMAL OPERATING TEMPERATURE, VEHICLE IS PARKED ON A LEVEL SURFACE AND ENGINE OFF FOR 10 MINUTES TO ENSURE ALL ENGINE OIL HAS RETURNED TO OIL PAN. USE THE SHORT STICK METHOD DESCRIBED IN PCED HARD START/NO START DIAGNOSTIC SUBROUTINES-SECTION 4. IF OIL IS OVERFULL, CHECK THE CHARGE AIR COOLER (CAC) FOR LIQUID CONTAMINATION. SOME RESIDUAL OIL IN THE CAC SYSTEM IS A NORMAL CHARACTERISTIC. IF THE CAC HAS EXCESSIVE OIL, ANY FUEL OR METAL CONTAMINATION, A THOROUGH CLEANING OF THE CAC SYSTEM IS NECESSARY. REFER TO WORKSHOP MANUAL SECTION 303-12 FOR CLEANING PROCEDURES AND PCED PINPOINT TESTS AND SYMPTOM CHARTS TO DIAGNOSE ROOT CAUSE OF OIL OVERFILL. 1664 - 2008 F-350/450/550 DUAL REAR WHEEL (DRW) REAR FENDER SIDE MARKER LAMPS LOOSE SEE TSB 08-23-10 FOR DETAIL 08-23-10 1647 - 1992-2008 MUSTANG/E-SERIES/F150/F-SUPER DUTY - AUTOMATIC TRANSMISSION INSTALLATION TIP TO PREVENT REPEAT AUTOMATIC TRANSMISSION FAILURES, CHECK FOR AND REPLACE ANY MISSING DOWEL PINS BEFORE INSTALLING THE TRANSMISSION. THE ORIGINAL DOWEL PINS ON THE ENGINE MAY HAVE COME OUT DURING THE INITIAL REPAIR OR REMOVAL OF THE TRANSMISSION. FAILURE TO HAVE BOTH DOWEL PINS INSTALLED CAN CAUSE A MISALIGNMENT BETWEEN THE CONVERTER AND THE PUMP. THIS MISALIGNMENT CAN LEAD TO TRANSMISSION FAILURE. 1643 - 6.0L DIESEL FUEL IN ENGINE COOLANT DIAGNOSTICS SEE TSB 08-23-08 FOR DETAIL 08-23-08 1577 - MODULE PREPROGRAMMING CONCERNS/ERRORS MAY BE CAUSED BY THE FOLLOWING: DATA LINK CONNECTOR (DLC) OR VEHICLE COMMUNICATION MODULE (VCM) BECOMING DISCONNECTED, LOW VOLTAGE ON THE IDS LAP TOP OR THE VEHICLE'S BATTERY, ALLOWING THE IDS TO ENTER ANY TYPE OF SLEEP MODE. IF THERE IS AN INTERRUPTION DURING REPROGRAMMING, DO NOT DELETE THE SESSION. MODULE RECOVERY IS ONLY POSSIBLE IF THE ORIGINAL SESSION IS USED| IF THE ORIGINAL SESSION HAS BEEN DELETED, THE ONLY WAY TO CORRECT THE CONCERN IS TO PURCHASE A NEW MODULE WHICH WILL NOT BE COVERED UNDER WARRANTY. 1574 - 2008-2009 SUPER-DUTY F250-550 6.4L DIESEL DIAGNOSTIC TROUBLE CODE U0073 SOME 2008-2009 F250-550 SUPER-DUTIES EQUIPPED WITH 6.4L DIESEL ENGINES MAY EXHIBIT AN INTERMITTENT NO CRANK CONCERN WITH DIAGNOSTIC TROUBLE CODE(DTC) U0073- CONTROL MODULE COMMUNICATION BUS A OFF. NETWORK DTCS ARE OFTEN A RESULT OF INTERMITTENT CONCERNS SUCH AS FAULTY WIRING, LOW BATTERY VOLTAGE OR MODULE REPROGRAMMING. REPLACING A MODULE TO RESOLVE A NETWORK DTC IS UNLIKELY TO RESOLVE THE CONCERN. CHECK FOR WIRE CHAFES OR PINCHED WIRES AND PERFORM A WIGGLE TEST ON CONNECTORS FOR THE FOLLOWING MODULES: RESTRAINT CONTROL, TRAILER BRAKE CONTROLLER. INSTALLATION OF AFTERMARKET THROTTLE CONTROLLERS AND BODY-BUILDER MODIFICATIONS MAY HAVE DAMAGED THE CAN NETWORK OR WIRING. CONFIRM THAT NO VEHICLE MODIFICATIONS HAVE BEEN TIED INTO THE CAN NETWORK. REFERENCE WORKSHOP MANUAL SECTION 418-00-1 FOR OTHER DTC DIAGNOSTIC ROUTINES. 1573 - 2009 F-SUPER DUTY - TRAILER TOW WIRING NOT INCLUDED AS STATED ON LOOSE ITEMS CHECKLIST ON SOME 2009 F-SUPER DUTY VEHICLES THE LOOSE ITEMS CHECKLIST STATES INCORRECTLY THAT A TRAILER TOW WIRING KIT IS INCLUDED WITH THE VEHICLE. THE ONLY VEHICLES WHICH WILL RECEIVE THIS KIT ARE CHASSIS CAB (NARROW FRAME) TRUCKS THAT ARE NOT EQUIPPED WITH A TRAILER BRAKE CONTROLLER (TBC). ENGINEERING IS CURRENTLY IN THE PROCESS OF CORRECTING THE LOOSE ITEMS CHECKLIST, CONTINUE TO MONITOR OASIS. 1572 - 2008 F-SUPER-DUTY 6.4L DIESEL - WHITE SMOKE DURING REGENERATION AT AMBIENT TEMPERATURES BELOW APPROXIMATELY 55 F(13 C) 2008 F-SUPER DUTY F250-550 EQUIPPED WITH 6.4L DIESEL ENGINES THAT EXHIBIT WHITE SMOKE DURING DIESEL PARTICULATE FILTER REGENERATION AT AMBIENT TEMPERATURES BELOW APPROXIMATELY 55 F(13 C). REPROGRAM THE APPROPRIATE VEHICLE MODULES PER FIELD SERVICE ACTION 08B07 BEFORE PERFORMING DIAGNOSTICS AND CLEARING ALL DIAGNOSTIC TROUBLE CODES(DTCS) FROM ALL MODULES. IF DTC'S ARE GENERATED AFTER REPROGRAMMING AND DTC CLEARING, FOLLOW NORMAL DIAGNOSTIC SERVICE PROCEDURES TO ADDRESS THESE DTC'S OR SYMPTOMS. 1571 - SOME VEHICLES MAY EXPERIENCE PROGRAMMING DIFFICULTIES RESULTING IN CORRUPT MODULE DATA OR BLANKED MODULES. HARDWIRE CONNECTIONS ONLY ARE RECOMMENDED DURING THE PROGRAMMING/REPROGRAMMING PROCESS. PAST REPORT INFORMATION INDICATES CONCERNS WITH WIRELESS IDS AS ROOT CAUSE. IN THE EVENT A MODULE BECOMES CORRUPT/BLANKED, ATTEMPT RECOVERY WITH A BATTERY CHARGER INSTALLED ON THE VEHICLE, IDS ON A WALL CHARGER, AND THE IDS PROGRAMMING CABLE TO THE VEHICLES DATA LINK CONNECTOR. IF THE MODULE CANNOT BE RECOVERED, MODULE REPLACEMENT MAY BE REQUIRED. 1568 - ANNOUNCING FIELD SERVICE ACTION 08B07 CUSTOMER SATISFACTION PROGRAM 08B07: CERTAIN 2008 MODEL YEAR F-SUPER DUTY VEHICLES EQUIPPED WITH A 6.4L DIESEL ENGINE REPROGRAM THE POWERTRAIN CONTROL MODULE (PCM) AND INSTRUMENT CLUSTER (IC). THIS HAS BEEN POSTED TO FMCDEALER.COM 1567 - ANNOUNCING FIELD SERVICE ACTION 08B06 CUSTOMER SATISFACTION PROGRAM 08B06: CERTAIN 2008 MODEL YEAR F-SUPER DUTY VEHICLES EQUIPPED WITH A 6.4L DIESEL ENGINE COOLING SYSTEM VENTURI TEE INSTALLATION. THIS HAS BEEN POSTED TO FMCDEALER.COM 1536 - 2008- 2009 SUPER-DUTY F250-550 - 6.4L DIESEL - U-CODE NETWORK TEST SOME 2008-2009 SUPER-DUTY F250-550 EQUIPPED WITH A 6.4L DIESEL MAY HAVE CODES U0073, U0100, U0121, P1000, U0074, U0101, U0115, U0164, OR ALL CMDTCS WHEN FIRST PERFORMING A NETWORK TEST AFTER IDS HAS ESTABLISHED A NEW SESSION. THESE CODES CAN BE EXPECTED AND SHOULD BE ABLE TO BE CLEARED. IF YOU CLEAR THESE CODES AND ANY OF THEM RETURN THEN INSPECT FOR A HARD FAULT LOSS OF COMMUNICATION. THE CODES ARE CAUSED BY A STRATEGY WHEN THE PCM AND THE IDS INTERACT WHILE ESTABLISHING COMMUNICATION. IF THESE CODES DO NOT RETURN AFTER CLEARING NO REPAIR RECOMMENDED. 1535 - 2008-2009 F-SUPER DUTY 6.4L - WIRE CHAFE/15-WAY CONNECTOR DIAGNOSTICS SOME 2008 F-SUPER DUTY 6.4L MAY EXHIBIT INTERMITTENT INJECTOR CIRCUIT OPEN DTC'S AND OR MISFIRE/ROUGH RUNNING AND/OR LACK OF POWER CONDITION. CHECK FOR POTENTIAL WIRE CHAFE AT DRIVER'S SIDE INJECTOR WIRE HARNESS CONTACTING BANJO FITTING ON THE FUEL FILTER HOUSING. VERIFY THE 15-WAY CONNECTOR TO ROCKER CARRIER IS FULLY SEATED. IF CONCERN REMAINS, REMOVE VALVE COVER FOR EFFECTED CYLINDER INJECTOR AND VERIFY THE ELECTRICAL CONNECTOR LOCKING TABS ARE FULLY SEATED ON ALL THE OTHER INJECTORS ON THAT BANK ARE FULLY SEATED. REMOVE ONLY ROCKER COVER(S) FOR INJECTORS INDICATED BY DTCS. IF SUSPECT CONNECTOR IS FULLY SEATED CONTINUE W/ NORMAL DIAGNOSTICS. NOTE: SOME UNDER VALVE COVER 15-WAY CONNECTIONS WERE SECURED BY AN O-RING. TO DISCONNECT THE O-RING MUST BE CUT. WHEN RECONNECTING THE CONNECTOR USE A 6" ZIP-TIE TO ENSURE THE CONNECTOR STAYS. 1486 - 2006-2009 F-SUPER DUTY - 4WD HUB USEAGE - SERVICE TIP THE OPTIMUM 4 WHEEL DRIVE FRONT HUB USEAGE FOR 2006-2009 F-SUPER DUTY VEHICLES, ADVISE CUSTOMERS OF THE FOLLOWING: 4WD USEAGE IS NOT RECOMMENDED ON DRY PAVEMENT. ON MANUAL SHIFT ON STOP (MSOS) 4X4 SYSTEMS IN 2WD MODE, ROTATE BOTH HUB LOCKS TO THE "FREE" POSITION. ON ELECTRONIC SHIFT ON THE FLY (ESOF) 4X4 SYSTEMS IN 2WD MODE, ROTATE BOTH HUB LOCKS TO THE "AUTO" POSITION. IT IS NOT RECOMMENDED TO OPERATE MSOS AND ESOF 4X4 SYSTEMS WITH THE HUB LOCKS IN THE "LOCK" POSITION. FOLLOWING THESE RECOMMENDATIONS WILL ENABLE PROPER DISENGAGEMENT OF THE TRANSFER CASE, DECREASE TIRE WEAR, IMPROVE FUEL ECONOMY AND MAY ALSO IMPROVE THE VEHICLES NOISE, VIBRATION AND HARSHNESS (NVH) CHARACTERISTICS BY REDUCING THE NUMBER OF MOVING COMPONENTS WHEN OPERATING IN 2WD MODE. REFER TO THE VEHICLES OWNER GUIDE FOR ADDITIONAL DETAILS. 1466 - 2003-2008 MULTIPLE VEHICLES - MISFIRE, LACK OF POWER, BUCK/JERK, EXCESSIVE SMOKE, CRANK/NO START - 6.0L ENGINE - DIAGNOSTICS FOR FUEL SYSTEM - SERVICE TIPS SEE TSB 08-20-01 FOR DETAIL 1465 - 6.0L EGR VALVE DIAGNOSTICS INVESTIGATION SOME 6.0L EQUIPPED VEHICLES MAY EXHIBIT DTC P0401, P0402, P0404, P1335 AND P1408 ALONE OR IN COMBINATION. DURING DIAGNOSTICS, PINPOINT TESTING MAY LEAD TO EGR VALVE REPLACEMENT. SOME NEW 6.0L EGR VALVES ARE FAILING THE EGRVP RESPONSE TEST (EGRDC VS. EGRVP) DURING THE IDS EGR AIR MANAGEMENT TESTING PROCEDURES. WHEN PERFORMING THE IDS EGR TEST, THE VALVES POSITION, ON OPENING, CAN CROSS THE LIMITS ON THE GRAPH TURNING IT RED AND FAILING THE TEST. ENGINEERING IS AWARE OF THE ISSUE AND IS INVESTIGATING. IF NO DRIVABILITY ISSUES ARE PRESENT, DO NOT REPLACE THE VALVE. IF DRIVABILITY ISSUES ARE PRESENT, PERFORM THE PERFORMANCE DIAGNOSTIC SHEET SKIPPING THE EGR PORTION. FOR OTHER DTC'S, FOLLOW THE APPROPRIATE PINPOINT TEST. 1464 - 2004-2008 E-SERIES/2003-2007 F-SUPER DUTY/2003-2005 EXCURSION/2006-2009 LOW CAB FORWARD/2004-2007 F650-F750 - OIL COOLER SERVICE TIP SOME 6.0L AND 4.5L DIESEL EQUIPPED VEHICLES MAY EXPERIENCE VARIOUS DRIVEABILITY SYMPTOMS AFTER OIL COOLER SERVICE. THIS MAY BE THE RESULT OF THE IPR BECOMING CONTAMINATED AND BEING UNABLE TO CONTROL ICP PROPERLY. IT IS STRONGLY RECOMMENDED TO COMPLETELY CLEAN OFF ALL OIL AND DEBRIS PRIOR TO OIL COOLER COVER REMOVAL AND TO INSPECT THE OIL PUMP INLET STRAINER SCREEN FOR DAMAGE PRIOR TO OIL COOLER REPLACEMENT. IF THE SCREEN IS DAMAGED, IT MUST BE REPLACED. THE RESERVOIR MUST BE COMPLETELY CLEANED TO ENSURE THERE IS NO CONTAMINATION TO THE HIGH PRESSURE OIL SYSTEM FROM DEBRIS ENTERING THE OIL DURING OIL COOLER REPLACEMENT. AFTER CLEANING, PRE-FILLING THE RESERVOIR WITH CLEAN OIL WILL HELP PREVENT EXTENDED CRANK TIME FROM AIR ENTERING THE HIGH PRESSURE OIL SYSTEM UPON ASSEMBLY. 1463 - 2009 F-SUPER DUTY - CARGO HOOK REPLACEMENT ON FACTORY SPRAY IN BEDLINERS ON 2009 F-SUPER DUTY UNITS WITH THE OPTIONAL SPRAY IN BEDLINER. THE BEDLINER MATERIAL IS SPRAYED IN AT THE ASSEMBLY PLANT. WHEN THE MATERIAL IS BEING APPLIED THE CARGO HOOKS ARE ALSO COVERED WITH THE BEDLINER MATERIAL. IF A CARGO HOOK IS BEING REPLACED ON A UNIT WITH THE FACTORY SPRAY IN BEDLINER THE CARGO HOOKS AND FASTENERS MAY BE REPLACED AS A SET SO THEY WILL MATCH. IMPORTANT - WHEN REMOVING CARGO HOOKS THE BEDLINER MATERIAL NEEDS TO BE CUT AROUND THE CARGO HOOK TO AVOID PULLING UP EXCESSIVE BEDLINER MATERIAL. 1462 - 2007-2008 VARIOUS VEHICLES - SATELLITE DIGITAL AUDIO RECEIVER SYSTEM (SDARS) LOW VOLUME AND/OR DTC U0196 AND/OR DVD WILL NOT PLAY OR EJECT THE DISC. SOME 2007-2008 VEHICLES EQUIPPED WITH REAR DIGITAL VIDEO DISC (DVD)/REAR ENTERTAINMENT MODULE (RETM), MAY EXHIBIT LOW VOLUME WHILE USING THE SATELLITE DIGITAL AUDIO RECEIVER SYSTEM (SDARS) AND/OR AUDIO CONTROL MODULE(ACM) DTC U0196, AND/OR RETM/DVD WILL NOT PLAY OR EJECT THE DISC. IF YOU ENCOUNTER THIS CONCERN, FIRST REMOVE AND REINSTALL THE F3 FUSE FROM THE SMART JUNCTION BOX (SJB) ON EXPEDITION, NAVIGATOR, EXPLORER, MOUNTAINEER, EDGE, MKX, TAURUS X, TAURUS, SABLE, F-SERIES SUPERDUTY / F4 FUSE FROM THE CENTRAL JUNCTION BOX (CJB) ON F150 AND MARK LT / F11 FUSE FROM THE SJB ON FIVE HUNDRED, MONTEGO AND RETEST. IF THE SYSTEM OPERATES NORMALLY, NO FURTHER SERVICE IS REQUIRED. IF THE CONCERN IS NOT REPAIRED USE THE WORK SHOP MANUAL, SECTION 415-00 FOR ADDITIONAL DIAGNOSTICS. 1443 - ANNOUNCING A NEW OASIS SYMPTOM CODE: 625000 EXTENDED IDLE SHUTDOWN. A NEW OASIS SYMPTOM CODE, 625000 EXTENDED IDLE SHUTDOWN UNDER THE DRIVABLITY CATEGORY, HAS BEEN ADDED REGARDING THE EXTENDED IDLE SHUTDOWN FUNCTION. THIS SYMPTOM CODE IS INTENDED TO DESCRIBE A VEHICLE EQUIPPED WITH AN EXTENDED IDLE SHUTDOWN FEATURE WHICH IS NOT SHUTTING DOWN AS EXPECTED. 1441 - RANGE INHIBIT LIGHT ON INSTRUMENT CLUSTER - NO ILLUMINATION - 2009 F650/750 BUILT BETWEEN 6/2/2008 - 6/26/2008 SEE TSB 08-19-12 FOR DETAIL 1425 - 6.0L HARD START/ NO START LOW INJECTOR CONTROL PRESSURE DIAGNOSIS SERVICE TIP PLEASE FAMILIARIZE YOURSELF WITH THE UPDATED HIGH PRESSURE OIL SYSTEM DIAGNOSTICS IN TSB 08-18-6. REMINDER: IF THE IPR VALVE SCREEN HAS FOREIGN MATERIAL, THEN REMOVE THE FOREIGN MATERIAL AND CONTINUE WITH IPR DIAGNOSTICS. IF THE IPR VALVE SCREEN IS FOUND TO BE DAMAGED THEN INSTALL A NEW IPR VALVE. THE PRESENCE OF FOREIGN MATERIAL ON THE SCREEN DOES NOT WARRANT HIGH PRESSURE PUMP OR IPR VALVE REPLACEMENT. 1420 - 2008 F-SUPER DUTY - 6.4L DIESEL ENGINE TICKING / TAPPING NOISE SEE TSB 08-19-05 FOR DETAIL 1387 - 2005-2007 F-SUPER DUTY, 2005-2008 E-SERIES AND 2005 EXCURSION - 6.0L HARD START / LONG CRANK / NO START - LOW INJECTOR CONTROL PRESSURE (ICP) SEE TSB 08-18-06 FOR DETAIL 1328 - 2008 LCF - HARD START, STUMBLE WITH ENGINE OIL TEMPERATURES (EOT) BETWEEN 68 - 122 DEGREES F (20 - 50 DEGREES C). SEE TSB 08-17-01 FOR DETAIL 1314 - ATTENTION DIESEL TECHNICIANS AND SERVICE MANAGEMENT PLEASE TAKE A MOMENT TO FAMILIARIZE YOURSELF WITH THE UPDATES TO TSB 08-16-13. THE TSB HAS BEEN UPDATED TO CLARIFY WHAT ACTIONS TO TAKE WHEN THERE IS CORROSION OR PITTING ON THE CENTER HOUSING FLANGE, HUB OR TURBINE HOUSING. WE HAVE ALSO UPDATED THE TURBO DRAIN TUBE INSPECTION. THANK YOU. 1313 - 1999-2008 7.3L/6.0L/6.4L/4.5L DIESEL - CLEAN THE CHARGE AIR COOLER (CAC) SYSTEM AFTER CERTAIN TURBO OR ENGINE FAILURES - SERVICE TIP ON A 7.3L, 6.0L, 6.4L, OR 4.5L DIESEL EQUIPPED VEHICLE IF THE TURBOCHARGER IS REPLACED FOR AN INTERNAL OIL LEAK OR COMPRESSOR SHAFT FAILURE, THE CHARGE AIR COOLER (CAC) SHOULD BE CHECKED FOR OIL CONTAMINATION AND CONSEQUENTLY CLEANED IF CONTAMINATION IS FOUND. THE CAC SHOULD ALSO BE INSPECTED AND CLEANED OF OIL, FUEL, OR METAL CONTAMINATION AFTER AN ENGINE FAILURE THAT MAY HAVE PUSHED OIL, FUEL, OR METAL INTO THE CAC DUE TO EXCESSIVE CRANKCASE PRESSURE. A THOROUGH CLEANING OF THE CAC SYSTEM IS NECESSARY TO PREVENT ENGINE DAMAGE OR DRIVABILITY CONCERNS. REFER TO THE WORKSHOP MANUAL SECTION 303-12 FOR PROPER CAC CLEANING PROCEDURES. IF EXHAUST SMOKE IS OBSERVED AFTER ENGINE REPAIRS AND THE CAC CLEANING HAVE BEEN COMPLETED REFER TO SYMPTOM CHART 8 IN THE PCED MANUAL. 1312 - 2008 LCF - MIL ON WITH UNKNOWN DTC 000 OR 0000. 2008 LCF VEHICLES MAY EXHIBIT A CHECK ENGINE LIGHT ON WITH AN UNKNOWN DTC 000 OR 0000 DISPLAYED. THIS CONDITION CAN BE CAUSED BY SCAN TOOL SOFTWARE OR ECU CALIBRATION NOT AT THE LATEST LEVELS. ENSURE MASTER DIAGNOSTIC SCAN TOOL SOFTWARE IS AT THE LATEST LEVEL (REVIEW PTS FOR LATEST SOFTWARE) AND RECHECK FOR DTCS. IF A RECOGNIZED DTC IS NOW RETRIEVED, PERFORM DIAGNOSTICS THROUGH NORMAL WSM / PC/ED DIRECTIONS/PP TESTS. IF 000/0000 DTC IS STILL RETRIEVED WITH LATEST LEVEL SOFTWARE, PERFORM AN ECM CALIBRATION UPDATE THROUGH NETS. SELECT THE "REFLASH - INSTALL NEW CALIBRATION" FUNCTION OF THE "GET" PROCESS. IF A RECOGNIZED DTC IS NOW RETRIEVED, PERFORM DIAGNOSTICS THROUGH NORMAL WSM / PC/ED DIRECTIONS/PP TESTS 1308 - 2003-2007 F-SUPER DUTY/2003-2005 EXCURSIONS/2004-2008 E-350/450 - 6.0L TURBOCHARGER CARBON DEPOSIT DIAGNOSTICS AND SERVICE TIPS SEE TSB 08-16-13 FOR DETAIL 1302 - 2008 LCF - CAC HOSE CONTACTING UPPER RADIATOR HOSE SEE TSB 08-16-11 FOR DETAIL 1300 - 2003-2008 MULTIPLE VEHICLES - MISFIRE, LACK OF POWER, BUCK / JERK, EXCESSIVE SMOKE, CRANK/NO START - 6.0L ENGINE - DIAGNOSTICS FOR FUEL SYSTEM - SERVICE TIPS SEE TSB 08-16-09 FOR DETAIL 1296 - 2008-2009 LCF - EXHAUST REGENERATION CONDITIONAL REQUIREMENTS 2008-2009 LCF VEHICLES REQUIRE SPECIFIC OPERATIONAL CONDITIONS FOR DIESEL PARTICULATE FILTER (DPF) EXHAUST REGENERATION TO OCCUR: MINIMUM SPEED OF 1 MPH (1.6KM/H) IS REQUIRED FOR DPF REGENERATION TO OCCUR. IF VEHICLE SPEED DROPS BELOW 1 MPH (1.6KM/H) DURING REGENERATION, THE PROCESS WILL GO INTO A HOLD MODE FOR UP TO 5 MINUTES OR UNTIL THE TRUCK BEGINS TO MOVE AGAIN. IF THE TRUCK DOES NOT ACHIEVE MORE THAN 1 MPH (1.6KM/H) WITHIN THE 5 MINUTE TIME, REGENERATION IS CANCELED. PLEASE REFER TO THE OWNERS GUIDE SECTION, "MAINTENANCE AND SPECIFICATIONS", FOR FURTHER DPF REGENERATION INFORMATION. 1292 - 2007 F-STRIPPED CHASSIS MOTORHOME - CRUISE CONTROL INOPERATIVE SOME 2007 F-STRIPPED CHASSIS MOTORHOMES BUILT ON 10/12/07 UP TO AND INCLUDING 10/31/07, MAY EXHIBIT AN INOPERATIVE CRUISE CONTROL DUE TO A LACK OF VOLTAGE SUPPLY FROM FUSE #27 LOCATED IN THE POWER DISTRIBUTION JUNCTION BOX(PDJB). INSPECT ALL CONNECTIONS AT PDJB, REFERENCING WIRING DIAGRAM BOOK SECTION 5 AND 31 TO ENSURE VOLTAGE SUPPLY AND CONNECTIONS FOR FUSE #27 ARE PRESENT AND SECURE. IF ALL CONNECTIONS AND VOLTAGE SUPPLY ARE PRESENT, CONTINUE WITH NORMAL DIAGNOSTICS IN WORK SHOP MANUAL SECTION 310-03. 1289 - 2008 F-SUPER DUTY 6.4L DIESEL ENGINE - CYLINDER CONTRIBUTION DIAGNOSTICS SEE TSB 08-16-07 FOR DETAIL 1280 - 2008 F-SUPER DUTY - 6.4L - VEHICLES BUILT BEFORE 4/23/2007 - ELECTRONIC THROTTLE CONTROL PEDAL REPLACEMENTS SEE TSB 08-16-02 FOR DETAIL 1279 - 2008 F-SUPER DUTY - 6.4L - VEHICLES BUILT BETWEEN 1/3/2008 AND 6/25/2008 - DIAGNOSTIC TROUBLE CODES P0128, P0196, P1335, P0404, P0406, P246C AND P2463 SEE TSB 08-16-01 FOR DETAIL 1276 - 2008 F650/F750 - CATERPILLAR EXHAUST REGENERATION CONDITIONAL REQUIREMENTS 2008 F650/F750 CATERPILLAR EQUIPPED VEHICLES REQUIRE SPECIFIC OPERATIONAL CONDITIONS FOR EXHAUST REGENERATION TO OCCUR: MINIMUM SPEED OF 20 MPH (32KM/H) IS REQUIRED FOR ACTIVE REGENERATION TO OCCUR. IF VEHICLE SPEED DROPS BELOW 5 MPH (8KM/H) DURING REGENERATION, THE PROCESS CANCELS WITHIN 3 MINUTES. REINITIATE BY RETURNING TO MINIMUM 20 MPH (32KM/H). SOOT LOAD LEVELS 1 OR HIGHER, MINIMUM SPEED IS REDUCED TO 5 MPH (8KM/H). IF THE VEHICLE SPEED FALLS BELOW TRIP POINT, SYSTEM ENTERS SOFT SHUTDOWN FOR 3 MINUTES. ENHANCED PASSIVE PLUS (EPP) CONTROLS SOOT LOAD DURING EXTENDED ENGINE OPERATIONS AT LOW IDLE. (REFERENCE CATERPILLAR OPERATION AND MAINTENANCE MANUAL FOR FURTHER DETAILS) REGENERATION TIMES GENERALLY ARE 10-30 MINUTES DEPENDING UPON SOOT LOAD LEVEL, TIMES MAY VERY DEPENDING ON OPERATIONAL CONDITIONS. 1273 - 2007-2008 F-SERIES MOTORHOME - CHASSIS LEAN SOME 2007-2008 F-SERIES MOTORHOMES MAY EXPERIENCE A CHASSIS LEAN CONDITION ON ONE OR MORE CORNERS, UPON THE INSTALLATION OF THE COACH. CHASSIS LEAN CONCERNS SHOULD FIRST BE DIRECTED TO THE COACH BUILDER TO ENSURE ALL BUILD SPECIFICATION MATCH THE CHASSIS REQUIREMENTS. MODIFYING THE CHASSIS SUSPENSION MAY NOT CORRECT A CONDITION CREATED BY THE COACH BUILDER AND SHOULD NOT BE PERFORMED WITHOUT THE COACH BUILDER'S AUTHORIZATION. 1247 - A NEW COMPRESSION TEST ADAPTER IS NOW AVAILABLE FOR FORD TRITON 3V ENGINES BUILT AFTER 10/2007 EQUIPPED WITH 12MM SPARK PLUGS. ORDER PART NUMBER STA73111 THROUGH THE ROTUNDA TECHNICIAN TOOL PROGRAM ON PTS, OR CALL 800-ROTUNDA OPTION 6. THE ADAPTER FITS BOTH 12MM AND 16MM SPARK PLUG HOLES AND IS EQUIPPED WITH QUICK-DISCONNECT COMPATIBLE WITH MANY COMPRESSION TESTERS. 1238 - 2004-2009 MEDIUM DUTY F-650/750 TRUCKS BUILT UP TO AND INCLUDING 7/9/2008 - AIR CONDITIONING VENTING DUE TO R-134A OVERFILL. SOME 2004-2009 MEDIUM DUTY F-SUPER DUTY 650/750 VEHICLES BUILT UP TO AND INCLUDING 7/9/2008, MAY EXHIBIT REFRIGERANT VENTING, POOR PERFORMANCE OR FREEZE UP IN WARMER CLIMATES. THIS MAY BE THE RESULT OF AN OVERFILLED R134A REFRIGERANT CONDITION. EVACUATE AND RECHARGE THE SYSTEM FOLLOWING WORKSHOP MANUAL SECTION 412-00, REDUCING THE AMOUNT OF REFRIGERANT TO 38 OZ. (1.07 KG) FROM 42 OZ. (1.19 KG). 1237 - 2008 F250-550 6.4L DIESEL RADIATOR REPLACEMENT VENTURI TEE INSTALLATION SOME 2008 F-SUPER DUTY 250-550 VEHICLES EQUIPPED WITH A 6.4L DIESEL ENGINE MAY REQUIRE A RADIATOR REPLACEMENT. AFTER FOLLOWING WORKSHOP MANUAL (WSM), 303-03 AND THE RADIATOR HAS BEEN IDENTIFIED AS THE CAUSE OF THE COOLANT LEAK AND IS TO BE REPLACED, IT IS NECESSARY TO ALSO INSTALL THE RADIATOR/VENTURI TEE SERVICE KIT 8C3Z-8B379-B. USE THE INSTRUCTION SHEET PROVIDED WITH THE KIT FOR PROPER INSTALLATION OF THE KIT. 1226 - A REVIEW OF WARRANTY RETURNED 6.0L HIGH PRESSURE PUMPS HAS FOUND MANY TO BE NOT DEFECTIVE. PLEASE REFER TO TSB 08-09-09 FOR COMPLETE HIGH PRESSURE FUEL SYSTEM DIAGNOSTICS. NOTE: IF THE IPR VALVE SCREEN HAS FOREIGN MATERIAL, THEN REMOVE THE FOREIGN MATERIAL AND CONTINUE WITH IPR DIAGNOSTICS IN TSB 06-13-03 OR HIGH PRESSURE FUEL SYSTEM TSB 08-09-09. IF THE IPR VALVE SCREEN IS FOUND TO BE DAMAGED THEN INSTALL A NEW IPR VALVE. THE PRESENCE OF DEBRIS ON THE SCREEN DOES NOT WARRANT HPP OR IPR VALVE REPLACEMENT. PUBLICATIONS ARE BEING UPDATED TO REFLECT THIS. 1206 - 2007-2008 VARIOUS VEHICLES - INTERMITTENT TPMS LIGHT WITH DTC'S B2872 AND B287A - CELL PHONE CHARGERS AND RF INTERFERENCE SOME 2007-2008 VEHICLES EQUIPPED WITH AN SPDJB MAY EXHIBIT AN INTERMITTENT TPMS LIGHT. DTC B2872 OR DTCS B2872/B287A MAY NOT IDENTIFY FAILED PARTS AND REPLACEMENT MAY LEAD TO REPEAT REPAIRS. SOME CELL PHONE CHARGERS CAN CREATE RF INTERFERENCE THAT DEGRADES TPMS PERFORMANCE. A DEVICE KNOWN TO CAUSE THE ISSUE IS A NAME BRAND CHARGER - MODEL MOTMINIVPC BUILT BEFORE 2007. TO IDENTIFY CHARGER, CHECK MODEL/SERIAL NUMBER ON THE PRODUCT TAG, THE 2 DIGIT YEAR FOLLOWS THE LETTERS "DC" - DC06XXXXXX. THIS ISSUE MAY BE CAUSED BY OTHER CHARGING DEVICES ALSO. ASK CUSTOMER TO PROVIDE THE CAR CELL PHONE CHARGER (OR SIMILAR DEVICE), ALONG WITH PHONE COMPLETELY DISCHARGED TO PERFORM A ROADTEST. IF DIAGNOSIS INDICATES CHARGER CAUSES INTERMITTENT TPMS LIGHT, ADVISE CUSTOMER TO OBTAIN A NEW CHARGER OR TO USE A DIFFERENT POWERPOINT LOCATION. 1203 - SOME 1997 THROUGH 2003 MY 7.3L VEHICLES MAY EXHIBIT A PHANTOM P0284, P0281, P0278, P0275, P0272, P0269, P0266, AND/OR P0263 DIAGNOSTIC TROUBLE CODE (DTC) SOME 1997 THROUGH 2003 MY 7.3L VEHICLES MAY EXHIBIT PHANTOM P0284, P0281, P0278, P0275, P0272, P0269, P0266, AND/OR P0263 DIAGNOSTIC TROUBLE CODES (DTC) WITHOUT DRIVABILITY SYMPTOMS IN CYLINDER CONTRIBUTION TEST (CCT) ON VEHICLES EQUIPPED WITH A NEW STYLE (GRAY) CMP SENSOR. THE NEW STYLE SENSOR WOULD HAVE BEEN INSTALLED UNDER SAFETY RECALL 07S57. ENGINEERING IS CURRENTLY WORKING ON A RESOLUTION TO ELIMINATE THE PHANTOM CODES. 1183 - 2008 F-SUPER DUTY - DISTANCE TO EMPTY (DTE) NOT ACCURATE ON 2008 F-SERIES SUPER DUTY VEHICLES, DISTANCE TO EMPTY (DTE) MAY SHOW 50 MILES TO EMPTY AND THE "LOW FUEL" MESSAGE MAY COME ON WITH THE INDICATED FUEL TANK LEVEL MORE THAN 1/8 (POSSIBLY AS MUCH AS 3/4) FULL. THIS CONDITION IS NORMAL, AND THE RESULT OF CUSTOMER SUBJECTING VEHICLE TO CONDITIONS WHICH ADVERSELY AFFECT THE VEHICLE'S FUEL ECONOMY (SUCH AS SNOW PLOWING, PTO, TOWING, ETC). DURING THIS TYPE OF OPERATION, IT IS POSSIBLE TO GET LOW ENOUGH MPG READINGS FOR A LONG ENOUGH TIME, TO GET THE "LOW FUEL" WARNING TO ACTIVATE WITH A SIGNIFICANT AMOUNT OF FUEL REMAINING IN THE TANK. NOTE: FORD HAS PROVIDED A RESERVE OF FUEL STILL AVAILABLE WHEN THE GAUGE READS E TO PROTECT THE CUSTOMER FROM RUNNING OUT OF FUEL (AS MUCH AS 5 GALLONS). AFTERMARKET ITEMS SUCH AS FUEL TANKS, NON-OEM TIRE SIZES, ETC. WILL ALSO AFFECT DTE. 1149 - 2004-2007 F-SUPER DUTY, 2004-2005 EXCURSION, AND 2004-2007 F-650/750 - LACK OF A/C COOLING SEE TSB 08-13-05 FOR DETAIL 1144 - 2008 F-SUPER DUTY - 6.4L - VEHICLES BUILT BETWEEN 8/3/2007 AND 1/3/2008 - MODULE REPROGRAMMING SEE TSB 08-13-03 FOR DETAIL 1143 - 2008 F-SUPER DUTY - 6.4L - VEHICLES BUILT PRIOR TO 8/3/2007 - MODULE REPROGRAMMING SEE TSB 08-13-02 FOR DETAIL 1139 - 2004-2008 F650/F750 MODULE COMMUNICATION CONCERNS - LACK OF VOLTAGE SUPPLY TO MODULES SOME 2004-2008 F650/F750 MEDIUM DUTY VEHICLES MAY EXPERIENCE AN INTERMITTENT MODULE COMMUNICATION CONCERN DURING CRANKING. THIS CONDITION CAN BE CAUSED BY A DROP IN SUPPLY VOLTAGE TO THE MODULE IN QUESTION AND MAY SET A COMMUNICATIONS DTC. WORK SHOP MANUAL (WSM) SECTION 303-06A-B-C, 414-00 AND 414-01 SHOULD BE REVIEWED TO ENSURE BATTERY/CHARGING AND STARTING SYSTEMS ARE OPERATING PROPERLY. IF NORMAL WSM DIAGNOSTICS DO NOT REVEAL A CONCERN, INSPECT FOR MODIFICATIONS TO THE BATTERY CABLING FROM THE BATTERY TO THE STARTER OR FROM THE STARTER TO THE BATTERY JUNCTION BOX. INSPECT BATTERY SUPPLY VOLTAGE TO THE MODULE IN QUESTION DURING CRANKING, AND ENSURE EACH CIRCUIT SUPPLYING VOLTAGE TO THE MODULE IS MEASURED FOR ANY VOLTAGE DROP. REPAIR ALL WIRING ISSUES USING WIRING DIAGRAM BOOKLET SECTION 5. 1096 - 2004-2007 MEDIUM DUTY F-650/750 - AIR CONDITIONING VENTING DUE TO R-134A OVERFILL SOME 2004-2007 MEDIUM DUTY F-650/750 VEHICLES MAY EXHIBIT AIR CONDITIONING VENTING, POOR PERFORMANCE OR FREEZE UP IN WARMER CLIMATES, THIS MAY BE THE RESULT OF OVERFILL OF R134A. EVACUATE AND RECHARGE THE SYSTEM IN ACCORDANCE OF THE WORKSHOP MANUAL SECTION 412-00 REDUCING FILL TO 1.02 KG (36 OZ)FROM 1.19 KG (42 OZ). 1085 - 2004-2007 F-650/F-750 - 6.0L - HARD START/LONG CRANK /NO START - LOW ICP SEE TSB 08-12-08 FOR DETAIL 1076 - ANNOUNCEMENT: NEW 6.4L SHORT BLOCK ASSEMBLIES, 8C3Z-6009-A ARE NOW AVAILABLE. DEALERSHIPS CAN PLACE ORDERS DIRECTLY TO FORD, THROUGH DOES II. A SHORT BLOCK ASSEMBLY SHOULD BE CONSIDERED WHEN MAKING DAMAGED ENGINE REPAIRS VS. COMPLETE ENGINE ASSEMBLIES. 1075 - ELECTRICAL MOTORS AND MODULES SOME COMPONENTS, ESPECIALLY ELECTRICAL MOTORS AND MODULES, LOOK THE SAME AND COULD EVEN BE CROSS INSTALLED IN DIFFERENT LOCATIONS. PLEASE TAKE CARE TO AVOID SWAPPING ELECTRICAL MOTORS OR MODULES IN SERVICE AS IT COULD RESULT IN OPERATIONAL DIFFICULTIES. EVEN THOUGH A PART LOOKS THE SAME AND CAN BE INSTALLED, UNLESS SPECIFICALLY INTENDED FOR THAT FUNCTION, IT MAY NOT OPERATE AS DESIGNED. ALWAYS CONSULT THE PARTS CATALOG FOR THE YEAR/MODEL TO DETERMINE THE PROPER PART APPLICATION FOR THE SPECIFIC REPLACEMENT NEEDED. FOR EXAMPLE: THE GLASS DRIVE SUNSHADE MOTORS ON VISTA ROOFS APPEAR IDENTICAL BUT FUNCTION DIFFERENTLY. 1072 - 2004-2008 F150/2006-2008 MARK LT/2005-2008 EXPEDITION/NAVIGATOR/F-SUPER DUTY 5.4L 3V ENGINE - MISC DRIVABILITY CONCERNS/VERIFY SCHEDULED MAINTENANCE COMPLETE SOME 2004-2008 F150 / 2006-2008 MARK LT / 2005-2008 EXPEDITION/NAVIGATOR/F-SUPER DUTY VEHICLES WITH 5.4L 3V ENGINE WITH GREATER THAN 60,000 MILES, THAT ARE SUBJECTED TO SPECIAL OPERATING CONDITIONS, MAY EXHIBIT MISFIRE DTCS AND IGNITION SYSTEM RELATED DRIVABILITY CONCERNS UNDER HIGH-LOAD OR WIDE OPEN THROTTLE (WOT). SPECIAL OPERATING CONDITIONS ARE DEFINED AS EXTENSIVE IDLING AND/OR LOW-SPEED DRIVING FOR LONG DISTANCES AS IN HEAVY COMMERCIAL USE SUCH AS DELIVERY, HEAVY TOWING, TAXI, PATROL CAR OR LIVERY. BEFORE ATTEMPTING REPAIRS, VERIFY RECOMMENDED 60,000 MILE SCHEDULED MAINTENANCE SERVICE HAS BEEN PERFORMED WHICH INCLUDES SPARK PLUG REPLACEMENT. REFER TO TSB 08-07-06 WHICH PROVIDES UPDATED SPARK PLUG REMOVAL PROCEDURE. IF SPARK PLUG REPLACEMENT DOES NOT CORRECT THE CONDITION CONTINUE WITH NORMAL PC/ED DIAGNOSTIC ROUTINES. 1038 - 2006-2007 LCF HIGH PRESSURE OIL SYSTEM LEAK - DTC 335 - HARD START/NO START - LOW POWER SEE TSB 08-11-09 FOR DETAIL 1031 - 2008 F650/F750 CHECK ENGINE LIGHT ON WITH J1938 DTC 111-1, 111-2, AND 111-17. AS STATED IN OASIS MESSAGE SSM 20092, SOME 2008 F650/F750 TRUCKS MAY TURN THE CHECK ENGINE LIGHT ON (WITH A POSSIBLE STOP ENGINE LIGHT) AT LOW COOLANT LEVELS. CHECK FOR PROPER COOLANT LEVEL PRIOR TO PERFORMING ANY PART REPLACEMENT. THE COOLANT LEVEL MUST BE SET TO THE MIDDLE OF THE UPPER SIGHT GLASS FOR NORMAL OPERATING TEMPERATURES. THIS CAN RESOLVE A CHECK ENGINE LIGHT ON FOR COOLANT LEVEL WARNING ISSUE WITHOUT REPLACING THE COOLANT LEVEL SENSOR. 1030 - ANNOUNCING THE EXPANSION OF THE EXISTING DIESEL ENGINE PRIOR APPROVAL PROGRAM TO INCLUDE SELECTED 6.0L DIESEL COMPONENTS. EFFECTIVE WITH REPAIRS DATED JUNE 1, 2008, ANY REPAIR THAT REQUIRES REPLACEMENT OF ANY OF THE FOLLOWING 6.0L COMPONENTS WILL REQUIRE PRIOR APPROVAL FROM THE TECHNICAL HOTLINE. 6K682 TURBO ASSEMBLY, 9A543-HP OIL PUMP, 6049-CYLINDER HEAD/6051-HEAD GASKET, 9P456-EGR COOLER AND 6A642-OIL COOLER. WHEN DIAGNOSTICS LEAD TO THE 6049-CYLINDER HEAD OR 6051-HEAD GASKET THE PRIOR APPROVAL MUST BE OBTAINED BEFORE REMOVING THE CYLINDER HEAD(S). THESE NEW REQUIREMENTS ARE FOR ALL NON-LEVEL ONE DEALERSHIPS. LEVEL ONE DEALERSHIPS ARE EXEMPT. SEE EFC0200609 FOR MORE DETAILS. 1021 - 2008 F-SUPER DUTY - POWER WINDOW NOISE - BUILT BEFORE 7/31/2007 SEE TSB 08-11-05 FOR DETAIL 1015 - 2003-2005 EXCURSION, 2003-2007 F-SUPER DUTY, 2004-2008 E-SERIES - COOLANT LOSS - 6.0L SEE TSB 08-11-03 FOR DETAIL 1012 - BEGINNING MAY 19TH 2008 A NEW WARRANTY PART COVERAGE LOOK-UP TOOL IS AVAILABLE ON GLOBAL OASIS TECHNICIAN WEB VIEWS THE NEW TOOL COMBINES THE INQUIRY PROCESS FOR BOTH WARRANTY & ESP. IN ADDITION TO ESP, THIS TOOL WILL PROVIDE WARRANTY COVERAGE VERIFICATION FOR * BASIC WARRANTY * BUMPER-TO-BUMPER * POWERTRAIN WARRANTY * SAFETY WARRANTY * CORROSION WARRANTY * DIESEL ENGINE WARRANTY * UNIQUE HYBRID COMPONENTS WARRANTY * EMISSIONS WARRANTY (FEDERAL AND CALIFORNIA) REFER TO EFC 0200608 FOR DETAILS 1003 - 2008 F-SUPER DUTY - NOISE/POP HEARD/FELT UNDER DRIVER-SIDE FLOOR PAN DURING AGGRESSIVE VEHICLE TURNING SOME 2008 F-SUPER DUTY VEHICLES MAY EXHIBIT A POPPING NOISE HEARD/FELT UNDER DRIVER FLOOR PAN DURING AGGRESSIVE TURNING, MORE NOTICEABLE COLD. 1)VEHICLE BUILD DATE BEFORE 6/1/07 APPLY MULTI-PURPOSE GREASE(XL-5) TO BODY MOUNT-TO-FRAME BRACKET TOP INTERFACE, ALL LOCATIONS (DO NOT REMOVE MOUNTS. 2)IF CAB REMOVED, RECHECK WORK/CLEARANCES {WSM,502-02}AND CHECK BODY MOUNT-TO-FLOOR PAN FASTENER TORQUE{103 NM/76 FT LB}. 3)VALIDATE 4X4 LOCKING HUB-SYS OPERATING {WSM,308-07A}. VALIDATE 4X4 SYSTEM OFF(NOISE TURNING WHILE 4X4 ENGAGED IS NORMAL) CONFIRM LOCKING HUBS IN AUTO AND NOT LOCKED POSITION. 4)INSPECT CLEARANCE,FLOOR PAN TO FRAME RAIL TOP LHS/RHS FROM A-PILLAR BODY MOUNT REARWARD. ENSURE NO PARTS GROUNDING OUT TO FLOOR PAN. 5)EXAMINE FRONT BRAKE ROTOR DUST SHIELDS DON'T INTERFERE WITH OTHER COMPONENTS. ISSUE UNDER INVESTIGATION, SUBMIT DETAIL GCR 1000 - 1999-2008 7.3L/6.0L/6.4L/4.5L DIESEL - CLEAN THE CHARGE AIR COOLER (CAC) SYSTEM AFTER CERTAIN TURBO OR ENGINE FAILURES - SERVICE TIP IF THE TURBOCHARGER IS REPLACED ON A 4.5L, 6.0L, 6.4L OR 7.3L DIESEL EQUIPPED VEHICLE FOR AN INTERNAL OIL LEAK OR COMPRESSOR SHAFT FAILURE, THE CHARGE AIR COOLER (CAC) SHOULD BE CHECKED FOR OIL CONTAMINATION AND CONSEQUENTLY CLEANED IF OIL CONTAMINATION IS FOUND. THE CAC SHOULD ALSO BE INSPECTED AND CLEANED OF OIL OR METAL CONTAMINATION AFTER AN ENGINE FAILURE THAT MAY HAVE PUSHED OIL/METAL INTO THE CAC DUE TO EXCESSIVE CRANKCASE PRESSURE. A THOROUGH CLEANING OF THE CAC SYSTEM IS NECESSARY TO PREVENT FURTHER DRIVABILITY OR ENGINE CONCERNS. UPDATED CHARGE AIR COOLER (CAC) CLEANING PROCEDURES ARE NOW AVAILABLE FOR 2008 MODEL YEAR SUPER-DUTIES EQUIPPED WITH 6.4L DIESEL ENGINES IN THE WORKSHOP MANUAL(WSM) SECTION 303-12. 0999 - 1999-2008 F-250 AND F-350 - MATCHING THE CORRECT 10.5 AXLE HOUSING AND PINION BEARING WHEN REPLACING 1999-2008 MY F250/350 10.5" REAR AXLE HOUSINGS MAKE SURE TO ORDER THE CORRECT PINION BEARINGS FOR THE HOUSING. THE 2008MY HOUSING IS ALL NEW AND REQUIRES A UNIQUE PINION GEAR TAIL AND HEAD BEARING, BE SURE TO ORDER 2008 PINION BEARINGS PER THE PARTS CATALOG. THE 2008MY HOUSING IS ALSO USED TO SERVICE OLDER MODEL VEHICLES, IF THE HOUSING NEEDS TO BE REPLACED. PINION BEARING SERVICE PARTS ARE STILL AVAILABLE FOR OLDER MODEL YEAR HOUSINGS. WHEN REPLACING PINION BEARINGS ALWAYS REPLACE THE CUP (RACE) AND BEARING AS AN ASSEMBLY. MIXING PRE-2008 BEARINGS WITH AN 2008 HOUSING OR VICE VERSA MAY RESULT IN CUSTOMER COMPLAINTS OF AXLE WHINE OR NOISE BECAUSE THE REQUIRED PRELOAD IS NOT ACHIEVED. 0998 - 2004-2008 F650/F750 SPICER MANUAL TRANSMISSION GEAR OIL IDENTIFICATION. SOME 2004-2008 SPICER MANUAL TRANSMISSION EQUIPPED F650/F750 VEHICLES MAY HAVE BEEN MISS-TAGGED WITH A LABEL ON THE TRANSMISSION FILL PLUG INDICATING SYNTHETIC TYPE FLUID IS PRESENT. TO PROPERLY IDENTIFY THE FLUID TYPE FOR THE TRANSMISSION, REVIEW THE FOLLOWING: ON LOW MILEAGE TRUCKS IT MAY BE POSSIBLE TO DETERMINE FLUID TYPE BY THE COLOR OF THE FLUID - AMBER INDICATES A MINERAL BASED FLUID - RED INDICATES A SYNTHETIC BASED FLUID. ON HIGHER MILEAGE VEHICLES, FLUIDS MAY TRANSITION TO A BROWNISH COLOR MAKING IT DIFFICULT TO IDENTIFY. CHECK FOR A LABEL PLACED ON TOP OF THE TRANS IDENTIFYING 80W90 GL1 FOR MINERAL BASED AND CD-50 FOR SYNTHETIC BASED FLUIDS. 0996 - FOR 2005 - 2008 VEHICLES WITH WITH CHROME BUMPER'S AND/OR RUNNING BOARDS AFTER THE WINTER SOME CUSTOMERS MAY EXPRESS A CONCERN OVER APPEARANCE ISSUES (RUST, DISCOLORING, FADING..) ON CHROME BUMPERS / RUNNING BOARDS. MOST BUMPERS / RUNNING BOARDS CAN BE RESTORED USING MOTORCRAFT BRIGHT METAL CLEANER ZC-15 PER THE CLEANING SECTION IN THE OWNERS GUIDE. THE WPAC EVALUATES AND CLEANS ALL RETURNS. BUMPERS / RUNNING BOARDS THAT CAN BE RESTORED BY CLEANING WILL BE SUBJECT TO CHARGE BACK. 0991 - 2008 F-SUPER DUTY - 6.4L - VEHICLES BUILT BETWEEN 1/3/2008 AND 5/5/2008 - DIAGNOSTIC TROUBLE CODES (DTCS) P0128, P0196, P1335, P0404 AND P0406 SEE TSB 08-10-02 FOR DETAIL 0987 - ANNOUNCING VENDOR PROGRAM 08V01 VENDOR PROGRAM 08V01:CERTAIN 2008 F650 AND F750 TRUCKS WITH ALLISON TRANSMISSION PARK PAWL ACTUATOR ASSEMBLY INSPECTION AND REPAIR. THE FOLLOWING HAS BEEN POSTED TO FMCDEALER.COM 0980 - 6.4L EGR REMOVAL TOOL DAMAGE CONCERNS SOME 6.4L EGR (303-1267) TOOLS MAY EXPERIENCE A STRIPPED BEARING RETAINING NUT. IF THE NUT BECOMES DAMAGED DURING EGR VALVE REMOVAL, INSPECT THE THREADED FORCING SCREW FOR DAMAGE AS WELL AND CALL ROTUNDA FOR REPLACEMENT COMPONENTS AT 1-800-ROTUNDA (768-8632) AND CHOOSE OPTION #5 AT THE PROMPT. DURING TOOL RE-ASSEMBLY REMEMBER TO USE LOC-TITE 262 AND NOTE THAT IT IS A LEFT HAND THREAD. PLEASE MAKE SURE THAT THE PILOT CUP TURNS FREELY AFTER RE-ASSEMBLY AS WELL. 0978 - 2005 EXCURSION / 2005-2008 F-SUPER DUTY - 5.4L / 6.8L - CORRECT PROCEDURE FOR CHECKING EVAP SYSTEM LEAKS ON 40 GALLON FUEL TANKS WHEN CHECKING FOR EVAP SYSTEM LEAKS ON 2005-2008 F-SUPER DUTY, 2005-2008 ECONOLINE OR 2005 EXCURSION VEHICLES EQUIPPED WITH FUEL TANKS 40 GALLONS AND GREATER, IT IS RECOMMENDED TO RUN THE VEHICLES ON BOARD EVAP MONITOR TEST WITHIN THE OBDII DRIVE CYCLE TEST. IT IS NOT RECOMMENDED TO PERFORM THE IDS/SCAN TOOL EVAP TEST ON VEHICLES WITH 40 GALLON AND GREATER FUEL TANKS, THIS MAY RETURN ERRONEOUS/INACCURATE RESULTS. 0976 - SOME 2005-2007 F-SUPER DUTY / 2005-2008 E-SERIES / 2005 EXCURSION - 6.0L - HARD START / LONG CRANK / NO START - LOW INJECTOR CONTROL PRESSURE (ICP) SEE TSB 08-09-09 FOR DETAIL 0973 - USE ONLY MOTORCRAFT PM-3 FOR 3V ENGINE SPARK PLUG REMOVAL TSB 08-07-06 WAS RECENTLY PUBLISHED TO PROVIDE IMPORTANT PROCEDURE UPDATES TO REMOVE SPARK PLUGS FROM 4.6 3V / 5.4L 3V / 6.8L 3V ENGINES. IT IS IMPERATIVE THAT TECHNICIANS USE MOTORCRAFT CARBURETOR & TUNE-UP CLEANER, PART NUMBER PM-3, IN PLACE OF AEROKROIL PENETRATING OIL TO AID SPARK PLUG REMOVAL. PM-3 WAS TESTED EXTENSIVELY AND HAS PROVEN TO BE A SUPERIOR PRODUCT FOR THIS PROCEDURE. REFER TO THE TSB FOR ADDITIONAL SPARK PLUG REMOVAL DETAILS. 0969 - 2006-2007 F-53 MOTORHOME - AXLE NOISE (DANA S110/S130) SOME 2006-2007 F-53 MOTORHOMES BUILT ON OR BEFORE 2/1/2007 MAY PRODUCE A WHINE/GROWL NOISE COMING FROM THE REAR AXLE ASSEMBLY. DIAGNOSE AXLE NOISE USING WORK SHOP MANUAL (WSM) SECTION 205-00. IF INSPECTION OF INTERNAL COMPONENTS REVEAL NO WEAR CONCERNS, INSPECT AND ADJUST BACK LASH OF RING AND PINION 0.009"- 0.016" (0.23 - 0.41MM). IF NOISE PERSISTS AFTER BACK LASH ADJUSTMENT, REPLACEMENT OF RING AND PINION (W/BEARINGS) MAY BE NECESSARY AS REFERENCED IN WSM SECTION 205-00. IF RING AND PINION IS REQUIRED, DO NOT REPLACE DIFFERENTIAL CASE (CROSS SHAFT HALF ASSEMBLY) IF INSPECTION OF CASE REVEALS NO DAMAGE OR WEAR 0968 - ANNOUNCING FIELD SERVICE ACTION 08B03 FULL BULLETIN UPDATE: FULL BULLETIN...CUSTOMER SATISFACTION PROGRAM 08B03 - CERTAIN 2008 MODEL YEAR F-350, 4X4, 10,001 LBS AND OVER GVW, 156" WHEEL BASE VEHICLES EQUIPPED WITH A TWO-PIECE DRIVE SHAFT - FUEL TANK STOPPER BRACKET INSTALLATION. REFER TO FMCDEALER.COM FOR DETAILS. 0967 - ANNOUNCING FIELD SERVICE ACTION - COMPLIANCE RECALL FULL BULLETIN - 08C04 UPDATE: FULL BULLETIN...COMPLIANCE RECALL 08C04 - CERTAIN 2008 MODEL YEAR F-250 AND F-350, 4X4, SINGLE REAR WHEEL, 10,000 LBS AND UNDER GVW, 156" WHEEL BASE VEHICLES EQUIPPED WITH A TWO-PIECE DRIVE SHAFT - FUEL TANK STOPPER BRACKET INSTALLATION. REFER TO FMCDEALER.COM FOR DETAILS. 0966 - 2005-2008 F250-550 SUPER DUTY MANUAL TRANS - CLUTCH PEDAL CONCERN SOME 2005-2008 F250-550 SUPER DUTY VEHICLES WITH A MANUAL TRANSMISSION MAY EXHIBIT A CLUTCH PEDAL CONCERN DESCRIBED AS "FALLS TO THE FLOOR", "CLUTCH PEDAL STAYS ON THE FLOOR", OR "CLUTCH PEDAL FEELS SPONGY". IF THE CONCERN IS DIAGNOSED AS THE CONTROL ASSEMBLY - CLUTCH HYDRAULIC ACTUATOR (BASE PART NUMBER 7C522), ENSURE THE HEAT SHIELD IS FULLY COVERING THE CLUTCH SLAVE CYLINDER END OF THE ASSEMBLY. IF THE HEAT SHIELDING IS NOT FULLY COVERING THE CLUTCH SLAVE CYLINDER, SLIDE THE HEAT SHIELDING TOWARD THE TRANSMISSION UNTIL THE FORWARD END OF THE SHIELD CONTACTS THE CYLINDER MOUNTING FLANGE AT THE TRANSMISSION HOUSING. 0963 - CONTACT 1-800-FORD-KEY FOR REMOTE START CONCERNS ON 2007 FREESTYLE, FIVE HUNDRED, MONTEGO, 2007 AND 2008 CROWN VICTORIA, GRAND MARQUIS, FUSION, FOCUS, MILAN, MKZ, MUSTANG, TOWN CAR, EXPEDITION, NAVIGATOR, EDGE, MKX, ESCAPE, MARINER, F-150, MARK LT, F-SUPER DUTY, RANGER, 2008 TAURUS, TAURUS X AND SABLE. FOR QUESTIONS ABOUT INSTALLING OR TROUBLESHOOTING ANY GENUINE FORD/LINCOLN/MERCURY REMOTE START OR VEHICLE SECURITY KIT, PLEASE CONTACT 1-800-FORD-KEY FOR ASSISTANCE. 0953 - 2008 F-SUPER DUTY, E-SERIES, AND F-53 MOTORHOME CHASSIS - 6.8L CRANKSHAFT DAMPER TOO LARGE FOR AFTERMARKET PTO SPIDER BRACKET. SOME F-SUPER DUTY, E-SERIES, AND F-53 MOTORHOME VEHICLES EQUIPPED WITH 6.8L ENGINE BUILT BETWEEN 9/27/2007 - 1/23/2008, HAVE A CRANKSHAFT DAMPER WITH AN INCORRECTLY SIZED POWERTRAIN TAKE OFF (PTO) PILOT BORE. AN AFTERMARKET PTO SPIDER BRACKET WILL NOT PROPERLY FIT. THE FUNCTION OF THE DAMPER IS NOT EFFECTED. ONLY AFTERMARKET USERS THAT WISH TO ATTACH A PTO SPIDER BRACKET WILL BE IMPACTED. PLEASE REFER TO http://WWW.FLEET.FORD.COM/TRUCKBBAS, QVM BULLETIN# Q-167 FOR FURTHER DETAILS. 0951 - 1999-2008 7.3L/6.0L/6.4L/4.5L DIESEL - CLEAN THE CHARGE AIR COOLER (CAC) SYSTEM AFTER CERTAIN TURBO OR ENGINE FAILURES - SERVICE TIP ON A 7.3L, 6.0L, 6.4L, OR 4.5L DIESEL EQUIPPED VEHICLE IF THE TURBOCHARGER IS REPLACED FOR AN INTERNAL OIL LEAK OR COMPRESSOR SHAFT FAILURE, THE CHARGE AIR COOLER (CAC) SHOULD BE CHECKED FOR OIL CONTAMINATION AND CONSEQUENTLY CLEANED IF OIL CONTAMINATION IS FOUND. THE CAC SHOULD ALSO BE INSPECTED AND CLEANED OF OIL OR METAL CONTAMINATION AFTER AN ENGINE FAILURE THAT MAY HAVE PUSHED OIL/METAL INTO THE CAC DUE TO EXCESSIVE CRANKCASE PRESSURE. A THOROUGH CLEANING OF THE CAC SYSTEM IS NECESSARY TO PREVENT FURTHER DRIVABILITY OR ENGINE CONCERNS. 0947 - 2008 E-SERIES, SUPER DUTY OR RANGER - NO CRANK, CRANK/NO START WITH P1260 DTC NON-PATS AND PATS KEY EQUIPPED. 2008 E-SERIES, SUPER DUTY OR RANGER HAVE PATS SYSTEMS AND KEYS AS OPTIONAL EQUIPMENT. ALL 2008 E-SERIES, SUPER DUTY OR RANGER (WITH OR WITHOUT PATS KEYS) REQUIRE A PATS "HANDSHAKE"(KEY CYCLE) BETWEEN THE IC AND THE PCM TO ENABLE STARTING AND WILL SET A P1260 IN THE PCM IF THIS ENCRYPTED COMMUNICATION DOES NOT OCCUR. IF THE INSTRUMENT CLUSTER (IC) OR THE PCM IS/OR HAS BEEN REPLACED (OR BOTH), THE PARAMETERS MUST BE RESET AFTER THE 10 MIN ACCESS HAS BEEN GRANTED. THIS PROCESS WILL INTRODUCE THESE MODULES TO EACH OTHER SO THEY CAN COMPLETE THE "HANDSHAKE" EACH TIME THE VEHICLE IS STARTED. IF THE PARAMETER RESET IS NOT COMPLETED THE VEHICLE WILL EXPERIENCE A PASSIVE ANTI-THEFT SYSTEM (PATS) NO-START WITH A P1260 DTC. THIS WILL OCCUR EVEN IF THE VEHICLE IS NOT EQUIPPED WITH PATS. REFER TO PASSIVE ANTI-THEFT SYSTEM PARAMETER RESET IN WSM 419-01-1. 0933 - 2008 F-SUPER DUTY 250-550 - TRAILER TOW RATINGS FOR 3.55 GEAR RATIO EQUIPPED VEHICLES. WHEN REFERENCING THE 2008 RV AND TRAILER TOWING GUIDE THE NEW 3.55 AXLE RATIO IS NOT LISTED. TO DETERMINE TOWING CAPABILITIES OF TRUCKS EQUIPPED WITH A 3.55 GEAR RATIO REFER TO THE 3.73 AXLE RATIO DATA (THE NEW 3.55 AXLE RATIO IS RATED THE SAME AS THE 3.73 RATIO FOR TOWING CAPACITIES). 0905 - ANNOUNCING SAFETY RECALL 08S04 ANNOUNCING SAFETY RECALL 08S04 - CERTAIN 2008 MODEL YEAR ECONOLINE E350 VEHICLES - DRIVESHAFT INSPECTION/REPLACEMENT. THE DEALER BULLETIN HAS BEEN POSTED TO FMCDEALER.COM. 0903 - 2008 E-SERIES/RANGER - NO CRANK, CRANK/NO START WITH P1260 DTC NON-PATS AND PATS KEY EQUIPPED. 2008 E-SERIES/RANGER HAVE PATS KEYS AS AN OPTIONAL SYSTEM. ALL 2008 E-SERIES AND RANGER (WITH OR WITHOUT PATS KEYS) REQUIRE A PATS "HANDSHAKE"(KEY CYCLE) BETWEEN THE IC AND THE PCM TO ENABLE STARTING AND WILL SET A P1260 IN THE PCM IF THIS ENCRYPTED COMMUNICATION DOES NOT OCCUR. IF THE INSTRUMENT CLUSTER (IC) OR THE PCM IS/OR HAS BEEN REPLACED (OR BOTH), THE PARAMETERS MUST BE RESET IN BOTH MODULES OR THE VEHICLE WILL EXPERIENCE A PASSIVE ANTI-THEFT SYSTEM (PATS) NO-START WITH A P1260 DTC. THIS WILL OCCUR EVEN IF THE VEHICLE IS NOT EQUIPPED WITH PATS. PATS VEHICLES AND NON-PATS VEHICLES HAVE PARAMETERS IN THE IC AND THE PCM AND THEY MUST BE RESET WHENEVER EITHER (OR BOTH) MODULE(S) IS (ARE) REPLACED. REFER TO PASSIVE ANTI-THEFT SYSTEM (PATS) PARAMETER RESET IN WSM 419-01-1. 0900 - 2008 F250-550 SUPER-DUTY 6.4L DIESEL - MESSAGE CENTER W/DTC P246C AND/OR P2463 SOME 2008 F250-550 SUPER-DUTY VEHICLES EQUIPPED WITH A 6.4L DIESEL ENGINE MAY EXHIBIT A CONTINUOUS DISPLAY OF DRIVE TO CLEAN IN THE INSTRUMENT CLUSTER MESSAGE CENTER WITH DIAGNOSTIC TROUBLE CODES(DTC) P246C: DPF RESTRICTION - FORCED LIMITED POWER AND/OR P2463: DPF RESTRICTION - SOOT ACCUMULATION. THIS IS DUE TO VOLTAGE BEING APPLIED TO POWER-TAKE-OFF(PTO) PCM PIN C1-30 WHEN PTO OPERATION OR STATIONARY ELEVATED IDLE CONTROL(SEIC) IS DISENGAGED/INACTIVE. 12 VOLTS MUST ONLY BE APPLIED TO PTO ECM PIN C1-30 WHEN PTO, STATIONARY ELEVATED IDLE CONTROL(SEIC) AND APPROPRIATE SAFETY ENABLERS (SEE QVM 162R1, PAGE 15 HTTPS://WWW.FLEET.FORD.COM/TRUCKBBAS/TOPICS/QVMP.HTML) ARE ACTIVATED. 0897 - 2008 F250-550 SUPER-DUTY - 6.4L DIESEL - TICKING,TAPPING NOISE, HOT ENGINE. SOME 2008 F250-550 SUPER-DUTY EQUIPPED WITH A 6.4L DIESEL ENGINE MAY EXHIBIT A RANDOM TICKING/TAPPING NOISE THAT IS MOST AUDIBLE ON A HOT ENGINE AND IS MOST NOTICEABLE AT THE REAR OF THE ENGINE AND INSIDE THE FRONT WHEEL WELLS. THE NOISE RESONATES THROUGH THE CYLINDER BLOCK AND OR HEADS IS HEARD AS A METALLIC TICKING OR TAPPING SOUND, LIKE A SPARK PLUG WIRE ARCING OR LIFTER TICK.THE TICKING OR TAPPING NOISE CAN COME AND GO AND HAS A NONRHYTHMIC PATTERN. ENGINEERING IS AWARE OF THIS NOISE AND HAS AN INVESTIGATION UNDERWAY. AT THIS TIME, THE NOISE IS CONSIDERED AS A NORMAL OPERATING CHARACTERISTIC OF THE ENGINE. THE NOISE HAS NO SHORT OR LONG TERM EFFECTS ON THE ENGINE. DEALERS SHOULD NOT ATTEMPT TO COMPARE ANY CUSTOMER VEHICLES EXHIBITING THIS NOISE WITH OTHER SIMILAR VEHICLES AS THE NOISE IS DIFFERENT FROM VEHICLE TO VEHICLE. MONITOR OASIS FOR UPDATES. 0896 - 2008 F250-550 SUPER-DUTY - 6.4L DIESEL - COOLANT LOSS DIAGNOSTICS SOME 2008 F250-550 SUPER-DUTY VEHICLES EQUIPPED WITH A 6.4L DIESEL ENGINE MAY EXHIBIT COOLANT EXPULSION FROM THE DEGAS BOTTLE. PRIOR TO MAKING ANY REPAIRS VERIFY THE COOLANT LEVEL IS NOT OVERFULL. THE COOLANT LEVEL SHOULD BE WITHIN THE COLD FILL RANGE ON THE DEGAS BOTTLE. IF NOT OVERFILLED AND STILL EXPELLING COOLANT PLEASE REVIEW UPDATED DIAGNOSTIC WORKSHOP MANUAL(WSM) PROCEDURES IN ENGINE COOLING SECTION 303-03. NOTE THAT SOME PRESSURE TEST EQUIPMENT MAY RESULT IN A FALSE LEAK INDICATION WHEN ATTACHED DIRECTLY TO THE DEGAS BOTTLE CAP. PRESSURE TESTING SHOULD ONLY BE CONDUCTED WITH THE CAP INSTALLED ON THE DEGAS BOTTLE, AS CLARIFIED IN THE UPDATED WSM. 0867 - HORN CONCERN FOR SOME 2001-2007 F-SD VEHICLES SOME 2001-2007 F-SD VEHICLES MAY HAVE A CONCERN WITH THE HORN AS A RESULT OF THE HORN SWITCH LOCATED WITHIN THE DRIVER AIR BAG MODULE. THE HORN SWITCH CAN NOW BE SERVICED SEPERATELY WITH SERVICE KIT P/N 6C3Z-13B802-B. REFER TO SECTION 413-06 OF THE ON-LINE WSM AND SSM 19926 FOR THE REPAIR PROCEDURES. IT IS NO LONGER NECESSARY TO REPLACE THE DRIVER AIR BAG MODULE ASSEMBLY TO RESOLVE HORN CONCERNS ON THESE VEHICLES. 0888 - 2008 E-SERIES ABS/RSC LIGHT ON CODES C1145, C1155, C1165 OR C1175 BUILT ON OR BEFORE 1/18/2008 SEE TSB 08-08-04 FOR DETAIL 0887 - 2008 E-SERIES - 6.0L VEHICLES BUILT 11/1/2007 THROUGH 1/15/2008 - RUNS ROUGH, MISS, STUMBLE/FLUTTER BETWEEN 1500-4000 RPM - BROKEN CRANKCASE-TO-HEAD TUBES SEE TSB 08-08-03 FOR DETAIL 0885 - 2004-2007 F-SUPER DUTY 650/F750 AND 2006-2007 LCF - NETS SOFTWARE ERROR CODE 99 SEE TSB 08-08-01 FOR DETAIL 0866 - SPARK PLUG REMOVAL INSTRUCTIONS 4.6L 3V / 5.4L 3V / 6.8L 3V SEE TSB 08-07-06 FOR DETAIL 0863 - SPARK PLUG PORCELAIN REMOVAL - ROTUNDA TOOL KIT 303-1398 - 4.6L 3V / 5.4L 3V/ 6.8L 3V ENGINES ROTUNDA TOOL KIT 303-1398 IS BEING SHIPPED TO DEALERS BEGINNING 3/26/2008. DEALERSHIPS SHOULD EXPECT TO RECEIVE THE KIT WITHIN THE NEXT 15-20 DAYS. THESE KITS WILL AID IN REMOVAL OF BROKEN SPARK PLUG PORCELAIN FROM 4.6L 3V/ 5.4L 3V / 6.8L 3V ENGINES. DETAILED TOOL KIT INSTRUCTIONS WILL BE PROVIDED IN A TECHNICAL SERVICE BULLETIN AVAILABLE BY 4/4/2008. ADDITIONALLY A NEW TECH TIME PLUS EPISODE PROVIDING AN OVERVIEW OF THE KIT WILL BE AVAILABLE AT FMCDEALER.COM NEAR FUTURE. 0857 - 2008 E-SERIES ABS/RSC LIGHT ON - CODES C1145, C1155, C1165 OR C1175 BUILT ON OR BEFORE 1/18/2008 SEE TSB 08-07-05 FOR DETAIL 0840 - 2008 F650/F750 CUMMINS ENGINES EQUIPPED WITH VERTICAL EXHAUST/LESS RAIN CAP. SOME 2008 F650/F750 VEHICLES CAN BE ORDERED WITH VERTICAL EXHAUSTS AND MAY BE ORDERED WITH AN EXHAUST RAIN CAP. NOTE THAT CUMMINS EQUIPPED VERTICAL EXHAUSTS ARE DESIGNED WITHOUT A RAIN CAP AND SHOULD NOT BE EQUIPPED/MODIFIED TO INCLUDE ONE. A DESIGN CHANGE IN THE VERTICAL STACK PIPE ON CUMMINS EQUIPPED VEHICLES REQUIRES NO RAIN CAP BE INSTALLED (AN ORDER GUIDE CORRECTION WILL BE MADE TO REFLECT THIS). WATER DRAINAGE IS PROVIDED BY DRAIN PORTS IN THE OUTLET SECTION OF THE EXHAUST AFTERTREATMENT SYSTEM. 0838 - 2007-2008 MULITPLE VEHICLES - SMART POWER DISTRIBUTION JUNCTION BOX (SPDJB) CIRCUIT FAULT DISABLE FEATURE THE SMART POWER DISTRIBUTION JUNCTION BOX (SPDJB) IN CERTAIN 2007-2008 VEHICLES HAVE BUILT-IN FUNCTIONALITY TO DISABLE CIRCUITS. IF A CIRCUIT FAULT IS DETECTED, A DTC FOR THE AFFECTED CIRCUIT WILL BE SET IN THE SPDJB AND THE CIRCUIT OUTPUT IS DISABLED UNTIL THE DTC(S) ARE CLEARED AND THE SPDJB PASSES A SELF TEST. IF ELECTRICAL SYMPTOMS ARE PRESENT, PERFORM A SELF-TEST ON THE SPDJB AND CHECK FOR DTC'S. FOLLOW NORMAL SHOP MANUAL DIAGNOSTICS TO ISOLATE AND REPAIR THE AFFECTED CIRCUIT(S). ONCE THE FAULT HAS BEEN REPAIRED, CLEARING THE DTC(S) AND PASSING A SELF-TEST OF THE SPDJB WILL RESTORE OUTPUT ON THE AFFECTED CIRCUIT. NOTE: REPLACEMENT OF THE SPDJB SHOULD NOT BE NECESSARY TO RESTORE FUNCTIONALITY AND SHOULD ONLY BE DONE IF DIRECTED TO DO SO BY SHOP MANUAL DIAGNOSTICS. 0835 - ANNOUNCING COMPLIANCE RECALL 08C01 DEMONSTRATION / DELIVERY HOLD COMPLIANCE RECALL 08C01: CERTAIN 2008 MODEL YEAR F-250 THROUGH F-550 SUPER DUTY VEHICLES EQUIPPED WITH DRIVER SEAT LUMBAR FRONT DRIVER SEAT BACK INSPECTION AND REPAIR. THIS FSA HAS BEEN POSTED TO FMCDEALER.COM. 0818 - 2006-2007 F-53 MOTORHOME - AXLE NOISE (DANA S110/S130) SOME 2006-2007 F-53 MOTORHOMES BUILT ON OR BEFORE 2/1/2007 MAY PRODUCE A WHINE/GROWL NOISE COMING FROM THE REAR AXLE ASSEMBLY. DIAGNOSE AXLE NOISE USING WORK SHOP MANUAL (WSM) SECTION 205-00. IF INSPECTION OF INTERNAL COMPONENTS REVEAL NO WEAR CONCERNS, INSPECT AND ADJUST BACK LASH OF RING AND PINION (0.006"-0.016"). IF NOISE PERSISTS AFTER BACK LASH ADJUSTMENT, REPLACEMENT OF RING AND PINION (W/BEARINGS) MAY BE NECESSARY AS REFERENCED IN WSM SECTION 205-00. IF RING AND PINION IS REQUIRED, DO NOT REPLACE DIFFERENTIAL CASE (CROSS SHAFT HALF ASSEMBLY) IF INSPECTION OF CASE REVEALS NO DAMAGE OR WEAR. 0812 - 2008 F-SUPER DUTY 6.4L DIESEL DIESEL PARTICULATE FILTER(DPF) REPLACEMENT SERVICE SUGGESTION. VEHICLES BUILT BEFORE 8/3/07. IF NORMAL PC/ED DIAGNOSTIC PROCEDURES LEAD TO REPLACEMENT OF THE DIESEL PARTICULATE FILTER(DPF) ON 2008 F250-550 SUPER-DUTIES BUILT PRIOR TO 8/3/07 AND EQUIPPED WITH 6.4L DIESEL ENGINE PLEASE ENSURE THAT THE ENGINE CONTROL MODULE(ECM) IS REPROGRAMMED TO THE LATEST SERVICE CALIBRATION IDENTIFIED IN TSB 07-17-3. WHEN REPROGRAMMING THE ECM ON AUTOMATIC TRANSMISSION EQUIPPED VEHICLES THE TRANSMISSION CONTROL MODULE(TCM) WILL ALSO AUTOMATICALLY BE REPROGRAMMED TO THE LATEST LEVEL. 0808 - 2006-2007 LCF - RATTLE UNDER CAB OVER BUMPS - BUILT ON OR BEFORE 12/3/2007 SEE TSB 08-06-05 FOR DETAIL 0805 - 2008 F-SUPER DUTY - DISTANCE TO EMPTY (DTE) NOT ACCURATE SOME 2008 F-SUPER DUTY VEHICLES MAY EXHIBIT A DISTANCE TO EMPTY (DTE) CALCULATION THAT IS PERCEIVED AS NOT BEING ACCURATE (READS EMPTY BUT TANK IS NOT EMPTY). DTE IS CALCULATED USING A RUNNING AVERAGE FUEL ECONOMY, WHICH IS BASED ON THE RECENT DRIVING HISTORY OF 500 MILES (800 KM). DTE CAN BE RE-INITIALIZED IF THE BATTERY IS DISCONNECTED. ENGINEERING IS CURRENTLY INVESTIGATING THE CONCERN, PLEASE DO NOT REPLACE THE INSTRUMENT CLUSTER, AS THIS WILL NOT RESOLVE THE ISSUE. PLEASE CONTINUE TO MONITOR OASIS FOR UPDATES. 0804 - 2008 F-SUPER DUTY 6.4L - P040D DTC WITH A LACK POWER OR LACK OF BOOST SOME 2008 F-SUPER DUTY 6.4L MAY EXHIBIT A P040D DTC WITH A LACK POWER OR LACK OF BOOST. 6.4L DIESELS HAVE (3) DIFFERENT SENSORS USED IN (5) DIFFERENT LOCATIONS WITH THE SAME BASE PART NUMBER 12B591. THESE SENSORS ARE NOT ALL INTERCHANGEABLE AND IT IS IMPORTANT TO ORDER THE CORRECT SENSOR FOR YOUR REPAIR IN ORDER TO AVOID CUSTOMER DISSATISFACTION WITH EXCESSIVE DOWNTIME. THE PCED PPT WA7 AND SERVICE PARTS CATALOG HAVE BEEN UPDATED TO CLARIFY DIAGNOSTICS AND PART SELECTION. 0802 - 2008 FOCUS / F-SUPER DUTY - SMART POWER DISTRIBUTION JUNCTION BOX (SPDJB) PROGRAMMING ERRORS SOME 2008 FOCUS OR F-SUPER DUTY VEHICLES MAY EXHIBIT POWER DOOR LOCKS INOP, INTERIOR DOME LAMP FLASHING, AND/OR DTC'S FOR NON-OPTIONAL EQUIPMENT AFTER SPDJB REPLACEMENT/REPROGRAMMING. THIS CAN HAPPEN BY NOT FOLLOWING THE WORKSHOP MANUAL PROCEDURES OR SELECTING THE INCORRECT VEHICLE EQUIPMENT OPTIONS WHEN FOLLOWING THE IDS 'PROGRAMMABLE MODULE INSTALLATION' PROCEDURE. THE RESULT IS AN INCORRECT CONFIGURATION FILE DOWNLOADED INTO THE SPDJB DURING THE 'PROGRAMMABLE MODULE INSTALLATION' PROCESS. VERIFY THE IDS IS AT SOFTWARE LEVEL B53.5 P10 OR HIGHER AS IT CONTAINS UPDATES TO SPDJB PROGRAMMING PROCEDURE. 0791 - 2008 LCF -CHECK ENGINE LIGHT ON - VARIOUS DTCS / LACK POWER - BUILT ON OR BEFORE 1/21/2008. SEE TSB 08-06-02 FOR DETAIL 0785 - 2008 F-SUPER DUTY - 6.4L - DTC P0528 AND/OR P0529 SEE TSB 08-05-14 FOR DETAIL 0780 - 2006-2007 Low Cab Forward - SPEAKERS INOPERATIVE - WATER LEAK INTO DOORS SEE TSB 08-05-11 FOR DETAIL 0778 - 2008 F-SUPER DUTY 6.4L - MIL, P0006B, P2563, P2263 WITH R WITHOUT A DRIVABILITY COMPLAINT. SOME 2008 F-SUPER DUTY EQUIPPED WITH A 6.4L DIESEL ENGINE MAY EXHIBIT ONE OR MORE OF THE FOLLOWING DURING COLD WEATHER OPERATING TEMPERATURES AT OR BELOWFREEZING 32F (0C): DIAGNOSTIC TROUBLE CODES(DTCS) P006B, P2563, AND OR P2263 ACCOMPANIED BY SURGE AT IDLE, SURGE AT TEADY STATE SPEED, LACK OF POWER ON ACCELERATION AND TURBOCHARGER OVERBOOST CONDITION. IF NORMAL PCED DIAGNOSTIC PROCEDURES DO NOTLEAD TO SENSOR AND/OR COMPONENT REPLACEMENT DO NOT ATTEMPT URTHER REPAIRS. ENGINEERING IS CURRENTLY INVESTIGATING. MONITOR ASIS FOR UPDATES. 0755 - 2008 F-SUPER DUTY F-450 - AXLE WHINE NOISE BETWEEN 50-60MPH (80-97 KM/H) - WIDE FRAME WITH PICKUP BOX - DANA S110 SEE TSB 08-05-03 FOR DETAIL 0501 - 2008 F-SUPER DUTY 6.4L - DIAGNOSTIC TROUBLE CODES (DTC) P0128 AND P0196 SOME 2008 F-SUPER DUTY VEHICLES EQUIPPED WITH A 6.4L DIESEL ENGINE MAY EXHIBIT DTC P0128 ENGINE COOLANT THERMOSTAT AND/OR P0196 ENGINE OIL TEMPERATURE SENSOR CIRCUIT. IF NORMAL DIAGNOSTIC PROCEDURES DO NOT RESOLVE VEHICLE CONCERN DO NOT ATTEMPT FURTHER REPAIRS. ENGINEERING IS CURRENTLY INVESTIGATING. MONITOR OASIS FOR UPDATES. 20228 1999-2008 7.3L/6.0L/6.4L/4.5L DIESEL - CLEAN THE CHARGE AIR COOLER (CAC) SYSTEM AFTER CERTAIN TURBO OR ENGINE FAILURES - SERVICE TIP ON A 7.3L, 6.0L, 6.4L, OR 4.5L DIESEL EQUIPPED VEHICLE IF THE TURBOCHARGER IS REPLACED FOR AN INTERNAL OIL LEAK OR COMPRESSOR SHAFT FAILURE, THE CHARGE AIR COOLER (CAC) SHOULD BE CHECKED FOR OIL CONTAMINATION AND CONSEQUENTLY CLEANED IF OIL CONTAMINATION IS FOUND. THE CAC SHOULD ALSO BE INSPECTED AND CLEANED OF OIL OR METAL CONTAMINATION AFTER AN ENGINE FAILURE THAT MAY HAVE PUSHED OIL/METAL INTO THE CAC DUE TO EXCESSIVE CRANKCASE PRESSURE. A THOROUGH CLEANING OF THE CAC SYSTEM IS NECESSARY TO PREVENT FURTHER DRIVABILITY OR ENGINE CONCERNS. EFFECTIVE DATE: 04/23/2008 20209 2008 F250-550 SUPER-DUTY 6.4L DIESEL - MESSAGE CENTER W/DTC P246C AND/OR P2463 SOME 2008 F250-550 SUPER-DUTY VEHICLES EQUIPPED WITH A 6.4L DIESEL ENGINE MAY EXHIBIT A CONTINUOUS DISPLAY OF DRIVE TO CLEAN IN THE INSTRUMENT CLUSTER MESSAGE CENTER WITH DIAGNOSTIC TROUBLE CODES(DTC) P246C: DPF RESTRICTION - FORCED LIMITED POWER AND/OR P2463: DPF RESTRICTION - SOOT ACCUMULATION. THIS Link to comment Share on other sites More sharing options...
