mountaineer front axle oil baffle
Mekanik
I'm rebuilding the front axle in a 2003 mountaineer. The part number on the axle tag is: 1L2 3002 DH. There is an oil baffle that is located right behind the inner pinnion bearing cup. It got a little mangled when I was removing the inner bearing race. It looks like a shim and I cant seem to get the right part. My parts guy keeps getting the oil slinger that goes beetween the pinnoon seal and the outer pinnion bearing. Anybody else run into this and have the correct part number?
F0TZ-3070-A for the slinger as it's called in Microcat for the one that goes between the pinion seal and the outer pinion bearing. F0TZ-3070-C for the "baffle" as it's called in Microcat.
I thinks that where the problem is. I needed the part beetween the inner pinnion race and the case. I needed a FOTZ-3070-A. The part that they kept getting me was the slinger that goes beetween the outer pinnion bearing and the pinnion seal. It is interesting to note that 06 and later does not require this part because the lube passage is different. If I replaced the axle housing, I wouldn't need this part. I'm glad that problem is solved. It's time to move on to other problems... /forums/images/%%GRAEMLIN_URL%%/coffee.gif
