Tony302600 Posted August 19, 2008 Share Posted August 19, 2008 Anybody know what the 6.4 Special wrench kit number is for rotunda. I can't find the number i know the kit exists, has all the special wrenches we need to work on these motors? Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted August 19, 2008 Share Posted August 19, 2008 The red box triple set? TKIT-2006SD FLM Good Luck! Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted August 19, 2008 Share Posted August 19, 2008 Go to the Rotunda RTTP page and click "featured tools" it's right there. Product Details for RTTP-6.4L-KIT GearWrench 6.4L Torque Adapter Kit RTTP-6.4L-KIT ROTUNDA 1 - GearWrench 10mm/12mm half-moon shaped ratcheting wrench. 1 - GearWrench 11mm/13mm half-moon shaped ratcheting wrench. 1 - 11mm allen head socket, 3/8 drive. 1 - 12mm allen head socket, 3/8 drive. 1 - 10mm to 1/4 drive GearWrench socket adapter. 1 - 10mm 12 point deep socket, 1/4 drive. $79.95 NOTE: You may also want to pick up a Snap-On FRDHM15 because it's easier to torque the hp pump gear with this, not to mention easier for calculating the proper torque. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted August 19, 2008 Share Posted August 19, 2008 Uhghh! I was looking for this and totally missed it on the RTTP site. Not necessarily a bad thing but then I e-mailed them asking about it and it is right there like you pointed out. /forums/images/%%GRAEMLIN_URL%%/blush.gif There is one wrench that is not there that probably should be added and that is for the 15mm fuel pump gear bolt, Snap-On #FRDHM15. Quote Link to comment Share on other sites More sharing options...
Tony302600 Posted August 19, 2008 Author Share Posted August 19, 2008 Go to the Rotunda RTTP page and click "featured tools" it's right there. Product Details for RTTP-6.4L-KIT GearWrench 6.4L Torque Adapter Kit RTTP-6.4L-KIT ROTUNDA 1 - GearWrench 10mm/12mm half-moon shaped ratcheting wrench. 1 - GearWrench 11mm/13mm half-moon shaped ratcheting wrench. 1 - 11mm allen head socket, 3/8 drive. 1 - 12mm allen head socket, 3/8 drive. 1 - 10mm to 1/4 drive GearWrench socket adapter. 1 - 10mm 12 point deep socket, 1/4 drive. $79.95 NOTE: You may also want to pick up a Snap-On FRDHM15 because it's easier to torque the hp pump gear with this, not to mention easier for calculating the proper torque. Thanks /forums/images/%%GRAEMLIN_URL%%/thumbup.gif Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted August 20, 2008 Share Posted August 20, 2008 Quote: Quote: NOTE: You may also want to pick up a Snap-On FRDHM15because it's easier to torque the hp pump gear with this,not to mention easier for calculating the proper torque There is one wrench that is not there that probably should be added and that is for the 15mm fuel pump gear bolt, Snap-On #FRDHM15 Looks like Keith is still running a little behind /forums/images/%%GRAEMLIN_URL%%/coffee.gif Quote Link to comment Share on other sites More sharing options...
slim Posted August 20, 2008 Share Posted August 20, 2008 I haven't had to mess with the high pressure pump yet, what do you need the FRDHM15 adapter for? I am guessing a new pump doesn't come with a gear attached. I hate to be in the middle of job and need a tool. Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted August 20, 2008 Share Posted August 20, 2008 Quote: what do you need the FRDHM15 adapter for? This allows you to get a torque wrench on the hp pump gear bolt, which you can't get a socket on because the rear engine cover is in the way. Quote Link to comment Share on other sites More sharing options...
