flamesnbetty Posted July 28, 2005 Share Posted July 28, 2005 04 6.0L VAN 27000 MILES, NO BASE OIL PRESS. OIL PUMP AND REGULATOR GOOD, WHEN CRANKING NO OIL OUT OF REGULATOR. SHOULD THERE BE AND COULD A HIGH PRESSURE LEAK NOT ALLOW BASE OIL PRESSURE, ALSO REMOVED THE OIL PAN AND INSPECTED PICKUP TUBE PER HOTLINE. GETTING READY TO ADD AIR TO HIGH PRESSURE SYSTEM AND REMOVED IPR AND INSPECT, SEEMS LIKE WERE MISSING SOMETHING SIMPLE, ANY HELP. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted July 28, 2005 Share Posted July 28, 2005 If you crank the engine with the regulator plug out I would think that oil should gush out. Did you pull out the regulator valve from the bore and remove the oil pump gears when you inspected them? Quote Link to comment Share on other sites More sharing options...
flamesnbetty Posted July 28, 2005 Author Share Posted July 28, 2005 YES TO ALL OF THE ABOVE, REGULATOR SLID OUT AND THE GEARS ON THE PUMP LOOK FINE NO GROOVES, HAVE SEEN A BAD PUMP BEFORE, LOOKS FINE. JUST A LITTLE OIL CAME OUT WHEN CRANKING WITH REGULAOR OUT. SO NO OIL IT WOULD HAVE TO BE THE PUMP OR PICKUP TUBE OR SOMETHING WERE MISSING, THANKS FOR THE QUICK REPLY. Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted August 9, 2005 Share Posted August 9, 2005 We had a 6.0 with no base oil pressure - used the borscope through the drain plug hole to see what we could of the pick-up tube... wasn't great but it did help. Quote Link to comment Share on other sites More sharing options...
