C1236 on an F250
I've got an 06 F250 with an intermittent ABS light on,only code is a left rear wheel speed sensor fault. This truck has only one rear speed sensor in the center,and there's a TSB(07-9-8) that has you pull the rear cover and inspect the carrier bolts for a possible loose condition,also the cicuitry for chafing...
I pulled the cover and the carriers are gray colored from metal,and i suspect the metal film is confusing the sensor...
Anybody else ran into this? The truck only has 22K miles.
Life is like a jar of jalepenos,what u eat today may burn your ass tomorrow.
Put a sensor and pigtail on,it hasn't come back, cool beans...
Probably spent more time than needed on that one,TSB has you pull cover BEFORE replacing sensor,guess their having carrier bolt issues.
I do probably 90% warranty diesel work,they give the gravy to the hourly techs...goody goody gumdrops
