scott1984 Posted November 19, 2008 Share Posted November 19, 2008 95/96 model year super duty with APCM not working correctly. knowlegde is needed, it turns on and works fine but there is not rpm change it stays at 650-700rpms. Quote Link to comment Share on other sites More sharing options...
DwayneGorniak Posted November 19, 2008 Share Posted November 19, 2008 Are all the requirements for activation met? Park brake indicator coming on when park brake is applied? Is the neutral safety switch actually reading park in park or neutral if it is a standard? And are there any dtc's in the PCM? Quote Link to comment Share on other sites More sharing options...
scott1984 Posted November 19, 2008 Author Share Posted November 19, 2008 well the e-brake is mess up at the drum on trans for about 6 months. but was working okay and just quit last week been working fine the only dtc is p1111 system pass. i do not know about neutral safety switch but if it was messed up the truck would not start correctly right i don't know never messed with one before Quote Link to comment Share on other sites More sharing options...
kridd12 Posted November 24, 2008 Share Posted November 24, 2008 I have seen a few times the wires break at the back of the apcm where the wires go back up under the dash. Had one about a month ago do this. can't remember off the top of my head which wires they were but the thing read rpm and lit up but could not change rpm. Have also seen bad apcm's as well. Quote Link to comment Share on other sites More sharing options...
