Autoworker Posted November 28, 2008 Share Posted November 28, 2008 hello all just finished a f250 2008 came in no crank no comunication with moduals /manual enter able to pull codes all u codes for pcm/tcm/abs/icm /after a lot of verifing circutes came to the conclushion pcm at fault/day two install new pcm all ok network back up as built datta installed pats reset start truck all ok/sorry have to mention had a jobber remot starter/was disconeted at first/reasembe back out of garage in reverse put in drive no gears just like doing stall test /push back on lift/run self test tcm code P1910 - FF - (TCM)Reverse Lamp Control Circuit / Open /verifi lights working fine dattalogger notes fault /stold a tcm from new unit on the lot retest all back to normal/go on a kick ass road test and vau la tout a bon### hope this post helps some one really like the new site keep up the good work Quote Link to comment Share on other sites More sharing options...
