NETS slow?
I am trying to reprogam a LCF and have been waiting for a program for over a hour. Is NETS getting slower or am I having a problem. Usually when I do a reflash it is pretty quick. The message I keep geeting is "program not ready try agian later". I think maybe the one guy at Ford that send out the reflashes must have called in sick today. /forums/images/%%GRAEMLIN_URL%%/sick.gif
You need to call in and have tech release the file. The file should be ready to come back to you in 10-15 secs. You usually only get one chance to download a file. If you loose it for whatever reason you need to call in so they can release it again. Also be aware that went you select blank/replace module, that once you begin that process, the module is erased and the engine will not run until the program process is complete.
