kevin phillips Posted December 10, 2008 Share Posted December 10, 2008 I have a 2003 mach 1 with a 4r70w that exploded and sent metal into the entire unit.Trying to find a assembly short of buying a new one is tough because they are very few of them around.Anyone ever tried any other 4r70w's out of other vehicle's or know if anything else would interchange? Neighbors vehicle and would like to find a used one if i knew what would work.thanks Quote Link to comment Share on other sites More sharing options...
DamageINC Posted December 12, 2008 Share Posted December 12, 2008 Try looking into a trans from a Marauder, that's your best bet. I believe that a standard Crown Vic/Grand Marquis trans will work just fine as well but you might wanna do some more research first. This would be a lot easier if he had a 5-spd Mach but seeing as they came with 8-bolt cranks (the autos have a 6-bolt) he's gonn a have a limited choice of options for this one. Dave Quote Link to comment Share on other sites More sharing options...
kevin phillips Posted December 13, 2008 Author Share Posted December 13, 2008 thanks for the info,I have a 03 mustang gt trans coming that is supposed to work.The valve body is diffront than most of them but we will see. Quote Link to comment Share on other sites More sharing options...
