fjubain Posted December 12, 2008 Share Posted December 12, 2008 I got a customer stopped in today and told me that when he first start his truck in morming there is a large bleuish smoke from tail pipe,it won,t last long and ok hot, been doing this for a month now.THis ia a 2001 7.3l f series.He will leave it next week.Possible injector leaking ??? Any advise would be appreciated. Quote Link to comment Share on other sites More sharing options...
eastendpowerstroke Posted December 13, 2008 Share Posted December 13, 2008 If cold start smoke is the only concern and he had no other concerns like long crank times cold or needing to plug it in all the time, it probably has a few bad glow plugs. A leaking injector would more than likely leak all the time not just on a cold start. Some smoke (blueish/white) is normal on a "cold start" no matter what temp is out side but worsens as it gets colder. most 7.3's will start with two or three bad GP's but will have some not to happy holes till they get a little heat in them causing smoke. Quote Link to comment Share on other sites More sharing options...
