Steve Mutter Posted December 17, 2008 Share Posted December 17, 2008 can the rocker arms be changed without removing the fuel rail? getting my parts today just wounder if anyone has done this Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted December 19, 2008 Author Share Posted December 19, 2008 well I could not do it and just as well the push rod was bent,I don't think there is any easy repair on this diesel, still on the 6.4 learning curve Quote Link to comment Share on other sites More sharing options...
Tony302600 Posted December 28, 2008 Share Posted December 28, 2008 No. Been there done that. I've tried everything. You have to remove the fuel rail, and all the HP fuel lines under valve cover and at back of head to FP. Stupid design. VERY STUPID. Quote Link to comment Share on other sites More sharing options...
cbriggs Posted January 8, 2009 Share Posted January 8, 2009 I found that too, easy to get to the valve cover , but then it is a chain reaction, remove the fuel rail, then you have to replace hp fuel line to pump, so then it becomes cab off. Quote Link to comment Share on other sites More sharing options...
DieselD Posted January 13, 2009 Share Posted January 13, 2009 The front ones you can get. 1,3,2,4. its alot harder but I had number 5 swapped until I found a blown up lifter and had to take everything apart. you can unbolt the rail and being very very careful move it out of the way without removing the supply line. the back holes are pretty much screwed. try yanking the trans out then getting the lines that way. we have had good luck doing pumps and turbos with cab on and yanking the trans instead. Quote Link to comment Share on other sites More sharing options...
skidoo700 Posted August 19, 2009 Share Posted August 19, 2009 I have a #3 with the pushrod bent to crap in today. Can the rocker/ pushrod be replaced without removing the fuel rail? Will I need to remove the fuel lines or ??? If I remove the trans do the turbos etc still have to come off?? Quote Link to comment Share on other sites More sharing options...
skidoo700 Posted August 19, 2009 Share Posted August 19, 2009 Anyone?? Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted August 19, 2009 Share Posted August 19, 2009 Dwayne has the answer to your question before it was even asked. ^^^^^ Quote Link to comment Share on other sites More sharing options...
skidoo700 Posted August 19, 2009 Share Posted August 19, 2009 Ok got the rail loose did not touch the feed side. Removed the smashed pushrod (ball end pushed into the rod). Found the other pushrod for same cylinder broken. Cannot find the other 2inch piece. Anyone have something like this happen. What caused this in the first place and do I probably have other consequences. Rod bent etc?? Quote Link to comment Share on other sites More sharing options...
Brad Clayton Posted August 19, 2009 Share Posted August 19, 2009 Turn that frown upside down. Every bent push rod, I have came across be it a 6.0 or 7.3, has been valve and valve guide issues. The 6.4 has the same head as a the 6.0. Can't be sure if it applies in your case. Try pushing the valves down a smidge to see how they move. Quote Link to comment Share on other sites More sharing options...
Aaron Posted August 19, 2009 Share Posted August 19, 2009 Was gonna say, sounds to me like a valve didn't open when it was told to. Bad valve. BAD! Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted August 20, 2009 Share Posted August 20, 2009 Same here. Seized or very stuck valves. I have done a handful ranging from the 7.3L to the 6.4L. One engine actually shattered a pushrod... I have pictures somewhere. If this is the case the head will have to come off. I know we discussed this in the past but I cleaned the valve guides with a transmission valve body hone I bought through one of my tool mongers. Reassemble with new valves rockers and push rods and it's good! Quote Link to comment Share on other sites More sharing options...
