robp823 Posted January 7, 2009 Share Posted January 7, 2009 Customer complaint is vehicle shifts hard and is hard starting when cold . It has 146,884 on the odometer and its an ambulance.Well it sat out over night last night in 30 degree temps and when i went out to start it this morning it fired right up idled rough for a couple seconds but started right up. They keep the vehicle inside all the time too. The other complaint for the shifting i couldnt really verify except when it was cold it would take longer to shift and shift a little firm but after it warmed up it was fine.There was a couple tsb's for this 07-14-08 and 06-02-04 for pcm reprogramming but this thing is at the highest calibration already. Trans fluid is at correct level and practically new looking and there is no dtc's at all did all self test. Any help appreciated! Quote Link to comment Share on other sites More sharing options...
mchan68 Posted January 7, 2009 Share Posted January 7, 2009 Customer complaint is vehicle shifts hard and is hard starting when cold .Explain to customer that this is a normal strategy used by the PCM to bring TFT up quicker during cold soak (lower TCC duty cycle, trans. cooler bypass, harsher shifts etc.). As for the hard start cold. Isn't any diesel hard to start when it's cold? If there are no DTCs and everything else is within specs., do you really want to dig into an E-series, worst of all and E-series ambulance? Quote Link to comment Share on other sites More sharing options...
robp823 Posted January 8, 2009 Author Share Posted January 8, 2009 nope your absolutley right its just one of those persistant customers they complain about every little thing when they bring these ambulances in i swear alot of times its like chasing ghosts.It starts to drive you insane.Then my service manager and service writer stand there looking at me like why cant you find the problem???? Well because i really dont think there is one... Quote Link to comment Share on other sites More sharing options...
