2005 e-450 od light flashing
If it is a 6.0L there are known chafe points at the PCM bracket, the A/c lines next to the PCM, the front of the left valve cover and (I think) the dipstick bracket. All of that is in the same localized area. Remove the intake tube between the air filter and the turbo inlet pipe and you should be able to see if there is anything funny going on there.
