Navigator suspension
Hey guy's need a favor...My boss has a good friend with a 01 Navigator with air suspension that the rt frt shock is not working. He has replaced the shock, both links and the sensor harness connector for the leveling sensor, the connector was burnt. Is there something else that needs to be done??? I know I know...Free info Posted Image But I did buy all the parts from mother.
Any way to retrieve DTC's? You may need a wiring diagram and trace circuits. The burnt connector may signal further issues unless you have determined and fixed the cause. It may extend to having burnt out a circuit in the air suspension/evo module.
They took a closer look at the truck and with further inspection found the level switch on the rear axle broken. We will swap that out and see where we are at then. I already brought up the burnt connector being a end result of larger problems.
