dieseldoc Posted April 1, 2009 Share Posted April 1, 2009 A buddy of mine called last night and told me he lost overdrive in his 02 F350 with a 7.3. He said that it was surging for a while in overdrive and now it wont shift into it at all. I am not a transmission guy, litterally have almost no experience with autos. Is there any common issues with these trans that a guy should be aware of? He was going to see if there was any faults and get back to me. Thanks for the suggestions guys. Quote Link to comment Share on other sites More sharing options...
Aaron Posted April 2, 2009 Share Posted April 2, 2009 Can't explain the surging, but make sure the O/D OFF wiring isn't chafed on the column somewhere. Is the O/D light flashing? Lots of miles on this unit? Quote Link to comment Share on other sites More sharing options...
dieseldoc Posted April 2, 2009 Author Share Posted April 2, 2009 This ones got 150,000 miles on it. He was in a hurry and didnt give me much detail. I am in north dakota and he is in wyoming, troubleshooting this could be interesting. I told him he may have to take it in. Troubleshooting over the phone isnt going to be good for either of us. I told him to call me back when he had more time, and details. I will tell him to check for the chaffed wiring. I was just curious if there was a common issue with this. Thanks Quote Link to comment Share on other sites More sharing options...
Aaron Posted April 2, 2009 Share Posted April 2, 2009 OD light flashing or does it work when you press the OD cancel button? Quote Link to comment Share on other sites More sharing options...
Jim Warman Posted April 2, 2009 Share Posted April 2, 2009 Without codes and a trans drive cycle road test, we are pretty much in the dark, too... First order of the day... determine if the fault is INSIDE the trans or OUTSIDE the trans. If the problem is inside the trans, and the trans has 150K on it, maybe we already know where we should go.... Quote Link to comment Share on other sites More sharing options...
Mekanik Posted April 4, 2009 Share Posted April 4, 2009 The day I got back from my first transmission class I get a 97 F350 with the same problem. It also had a 4R100 or E4OD. Someone put a re-man trans in it probably for the same problem, but the service writer didn't ask why the trans was replaced in the first place. my first transmission job and a total cluster-fuck. It didn't take long to figure out that I had a chaffed wire in the steering column. The O/D light on the shifter was not working, so the customer didn't know that the overdrive was being commanded off and on. There is no way to say what it is at this point Quote Link to comment Share on other sites More sharing options...
