Clark Posted May 24, 2009 Share Posted May 24, 2009 Is anyone else having trouble with NETS lately? Its never worked great for me, but lately it seems as though its taking twice as long as normal, and thats IF it works and I dont have to restart the whole process. Alot of this may have to do with our old, beat to hell computers too, but Im just curious. Last truck I did an AFC on, I had to do it 3 times. Quote Link to comment Share on other sites More sharing options...
blown99 Posted May 27, 2009 Share Posted May 27, 2009 Are you using the IC-4 com box? If so, they have changed the way the programming is done, and it has slowed it down a lot, if you don't chnage the settings for the com box. It used to take 14mins to program an ecm for an AFC. Without changing the settings it will take 1.5 hrs. To check your settings, got to programs, vehcile diagnostics, IC-4 self test, int that window select the stability column. Set it to stability level of 2. When you are done programming, go back in and set the stability level back to 15. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Clark Posted May 28, 2009 Author Share Posted May 28, 2009 Hmmmm, Ill have to try that. I am using the IC-4, we just got 3 brand new ones, but I havent checked the settings. What do stability settings affect? Quote Link to comment Share on other sites More sharing options...
blown99 Posted May 28, 2009 Share Posted May 28, 2009 The stability levels affect the speed of the IC 4. We never had to worry about this until the release of the new AFC programs. There was very little word/info regarding the stability levels. My older lap top doesn't even have the ability to change the settings for some reason. (IC-$ self Test) Quote Link to comment Share on other sites More sharing options...
Clark Posted June 16, 2009 Author Share Posted June 16, 2009 Anyone else got the new NavCom?????? Updates without NETS!!!!!!!!!!!!!!!!!!!!!!!!! Hells yes. Quote Link to comment Share on other sites More sharing options...
