2 WIRE FUEL TEMP SENSOR PIGTAIL PART #
ChristopherH
Does anyone have a part # for the gray 2 wire pigtail for the 6.4 dsl fuel temp sensor? I think the coolant temp sensor and the 6.0 oil temp and air intake temp use the same pigtail--can't locate a part # for it anywhere though.
I had hoped to get back to you sooner. There are a lot of engine sensor and control connectors that are simply not available through Ford or Motorcraft. You are correct that the fuel temperature sensor is the same sensor as the ECT and EOT sensors for the 6.4L. This is one of those times salvaged harnesses become valuable. I will keep looking, let us know if you find anything.
Have you checked out this site yet?http://www.motorcraft.com/pdf/Wiring_Pigtails_Illustration_Guide.pdf You will have to "copy" and "paste", as the link does not work.
