jt-morgan Posted February 14, 2006 Share Posted February 14, 2006 I have an early 04 f250 6.0 with a bad turbo and the rear mounting bolt is frozen and the head is rounded. Anyone have a trick to remove the bolt? Quote Link to comment Share on other sites More sharing options...
gasgasman Posted February 14, 2006 Share Posted February 14, 2006 Use a torch to heat up the bolt. It is very important to use a "like new" 10mm socket. I have one reserved just for this purpose. Quote Link to comment Share on other sites More sharing options...
jt-morgan Posted February 15, 2006 Author Share Posted February 15, 2006 Thanks.I will try that next time. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted February 15, 2006 Share Posted February 15, 2006 If you don't have them, I recommend a set of those sockets made for stripped or rounded nuts and bolts. Saved my butt when the same thing happened to me. The advise about keeping and maintaining a like new 10mm socket at all times is priceless. /forums/images/%%GRAEMLIN_URL%%/thumbup.gif Quote Link to comment Share on other sites More sharing options...
Mekanik Posted February 16, 2006 Share Posted February 16, 2006 I've had this happen to me a couple of times. I use a cutting torch, and a mirror so I can see the bolt head that I'm cutting off Quote Link to comment Share on other sites More sharing options...
GregH Posted March 6, 2006 Share Posted March 6, 2006 If all else fails, remove everything attatched to the turbo - y-pipe clamp, cac tube, oil feed, etc. and the two easy bolts to get out. Then put a long prybar into the turbo outlet. Pry it up off the pedestal, then push the bar towards the driver's side of the vehicle. The bolt will snap off flush with the turbo and the pedestal will be undamaged. I assume you're replacing the turbo? Quote Link to comment Share on other sites More sharing options...
ErickBaker Posted March 25, 2006 Share Posted March 25, 2006 Greg's method works great, used that myself more than a few times. Quote Link to comment Share on other sites More sharing options...
Dzltech Posted March 27, 2006 Share Posted March 27, 2006 I HAVE RUN INTO THIS QUITE A FEW TIMES,I CUT THE BOLT OFF,AS WAS ALREADY POSTED OR CUT THE PEDISTAL OPEN TO PULL IT OUT Quote Link to comment Share on other sites More sharing options...
sixturbosix Posted June 22, 2006 Share Posted June 22, 2006 Our local power co.dropped off a 2003 f450 bucket truck yesterday at our dealer.I work on quite a few of there trucks still under warranty.This is their first one out of warranty.They were in the process of trying to remove the turbo themselves.They stripped the head on the rear bolt.I can't get it out with one of the socket type removers.Is this the year model with the bolt that can be broken with a prybar or is it the later style with the bolt that goes straight down.The guy that worked on it at their garage said he didnt think he was ready to work on any 6.0l's and he hoped that was the last problem he had out of their fleet of trucks with 6.0l's.I wanted to laugh so hard but I bit my toungue and said you will probably win the lottery before you have a problem out of another one of these trucks.He has only worked there 2 weeks.Ha Ha Quote Link to comment Share on other sites More sharing options...
FORDTKEN Posted June 23, 2006 Share Posted June 23, 2006 IVE ALSO TRIED A SMALL PIPE WRENCH AND TRIED TURNING RIGHT ON THE SPACER FOR THR BOLT ITS WORKED JUST ABOUT EVERY TIME Quote Link to comment Share on other sites More sharing options...
snw blue by you Posted June 23, 2006 Share Posted June 23, 2006 A torch, a mirror, and a 10mm twist socket will get em' everytime. Use a little patience, and you will not have to cut or break anything. Quote Link to comment Share on other sites More sharing options...
