dieseldoc Posted July 11, 2009 Share Posted July 11, 2009 I was looking in to getting a breakout box. I found some on ebay that look to be in good condition. Does anybody have the part numbers of the box itself and recommended adapters to get. Thanks for the input guys. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted July 11, 2009 Share Posted July 11, 2009 You did see this post, right? http://www.forddoctorsdts.com/forums/ubbthreads.php?ubb=showflat&Number=23547#Post23547 What do you want the BOB to adapt to? Ford EEC-IV (all pre 1996 OBD1 cars): 60 pin BOB 7.3: 104 pin BOB 6.0: OTC #3235 104 pin BOB (or equivalent) Rotunda 105-R0107 BOB adapter for 122 pin PCM ($406.00 retail list from Rotunda, and plenty in stock), you should be able to get it for around $300 with your Rotunda discount. 6.4: No BOB is available. Beware that some 104pin BOB's will work fine for 7.3 but not 6.0. The reason is the 6.0 overlay card won't work on other than the appropriate 104 pin BOB, see the Powerpoint for pictures. The 3235 OTC should be fine, and make sure it has the 4 "knobs" to lock the card in place. Look closely at the PP slides and you'll understand what I'm talking about. I have all of the IH BOB's and PN's if you need them. If you're searching Ebay you'll find a bunch of oddball BOBs for weird Fords like Probes and ABS. There's a 3235 OTC for $399 right now, which is a good deal for new. I've seen used 104 pins go for as little as $100 if you're patient. Good Luck! Quote Link to comment Share on other sites More sharing options...
dieseldoc Posted July 12, 2009 Author Share Posted July 12, 2009 As always Bruce you have the best information and it is so easy to understand. I work primarily on 94-03 7.3s. However there are more 6.0s coming off warranty everyday. Increasing my opportunities to learn more and gain experience with these engines. I have some time to watch for a really good deal. Will have to keep my eyes open. Thanks again Bruce yet one more reason why I love this site. Quote Link to comment Share on other sites More sharing options...
Shlep Posted November 12, 2010 Share Posted November 12, 2010 Bruce, are you sure that number is available from Rotunda? I tried searching and all I seem to get is number not found....then again it may be the Canadian site doing it's thing once again. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted November 12, 2010 Share Posted November 12, 2010 Which PN? These numbers are printed right on the BOBs themselves. Quote Link to comment Share on other sites More sharing options...
Shlep Posted November 12, 2010 Share Posted November 12, 2010 Rotunda 105-R0107 is the one I'm looking for, sorry I guess I should've been a little more clear.... it was a rough day lol Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted November 13, 2010 Share Posted November 13, 2010 I just looked up the pictures of the tool kit, the plastic box holding the adapters is clearly marked Rotunda 105-R0107, it contains two 122 to 104 pin adapters which are marked 122-EC46 and 122-T30. There is also an overlay sheet but I couldn't read if there is a separate PN on it. Good Luck! Quote Link to comment Share on other sites More sharing options...
Shlep Posted November 15, 2010 Share Posted November 15, 2010 Could someone check if these are still available from Rotunda? No matter what number I use I get the same old number not found on the Canadian side, and when I try the US side I get blocked. Quote Link to comment Share on other sites More sharing options...
Shlep Posted November 15, 2010 Share Posted November 15, 2010 I found it,and it's on order. Thanks for the numbers Bruce. Quote Link to comment Share on other sites More sharing options...
ktmlew Posted December 9, 2010 Share Posted December 9, 2010 Just listed my 104 pin for sale if anyone needs one... Quote Link to comment Share on other sites More sharing options...
