fjubain Posted July 24, 2009 Share Posted July 24, 2009 Just a heads up,maybe you experience guys out there already know this but i tought I would share this.Today was my fisrt oil cooler replacement on a 6.4l and the oil cooler actually comes out without removing the intake.I thought i should give it a try and it worked, it only comes out like this, first lift the front of the cooler upward tight up under the intake, then tilt the rear of the cooler out of the engine block and slide it out. It,s the only way it comes out, if you tilt the rear right away and attemtp to slide out , it won't go.it come out freely without any excess force. Today we practice to get it in and out a few time .Note removed the power strg pump to access the frt cooler bolts.I hope this helps .By the way I replaced the cooler for and oil leak. Quote Link to comment Share on other sites More sharing options...
Jeff_ Posted July 24, 2009 Share Posted July 24, 2009 Nice to know!!! did you do this cab on or off? Quote Link to comment Share on other sites More sharing options...
GregKneupper Posted July 24, 2009 Share Posted July 24, 2009 Been doing that way since the engine came out. The only different thing that I do is remove the cover on it first. Saves a ton of time. Quote Link to comment Share on other sites More sharing options...
Bruce Amacker Posted July 25, 2009 Share Posted July 25, 2009 I'm curious- what led you to replacing it? Does the temp separation rule still apply? (15*F or 25*F, whichever you prefer.....) Quote Link to comment Share on other sites More sharing options...
fjubain Posted August 6, 2009 Author Share Posted August 6, 2009 I changed the cooler for an oil leak, the cavity below the cooler was full of oil and no signs of gasket failure, so I replaced the entire cooler assy, per hotline they have seen quit a few. Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted May 6, 2011 Share Posted May 6, 2011 Nice to know!!! did you do this cab on or off?I have my first one that needs a egr cooler and oil cooler. Can this be done with the body on or is it best to remove the body? Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted May 6, 2011 Share Posted May 6, 2011 egr cooler and oil cooler failures should be independent of each other on a 6.4. it's not like the 6.0 where one causes the other thanks for the heads up, I always thought the intake needed to be removed Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted May 6, 2011 Share Posted May 6, 2011 egr cooler and oil cooler failures should be independent of each other on a 6.4. it's not like the 6.0 where one causes the other Thats what I thought, but when I called the hotline they wanted the oil cooler replaced as well. I will have to double check with them in the am Quote Link to comment Share on other sites More sharing options...
Matt Saunoras Posted May 6, 2011 Share Posted May 6, 2011 let us know what they say Quote Link to comment Share on other sites More sharing options...
Steve Mutter Posted May 6, 2011 Share Posted May 6, 2011 Ya they fucked up. No oil cooler Quote Link to comment Share on other sites More sharing options...
mchan68 Posted May 6, 2011 Share Posted May 6, 2011 Ya they fucked up. No oil coolerThanks for the info. If Cold Line can't distinguish between a 6.0L and 6.4L and it's associated difference in operating characteristics, WTF else are they good to assist us with? And the million dollar question becomes, what would've happened had you gone ahead and replaced the oil cooler and the truck wasn't fixed? Who would be eating that one? Quote Link to comment Share on other sites More sharing options...
lmorris Posted May 9, 2011 Share Posted May 9, 2011 Was told the same thing. I got the "When replacing the EGR cooler don't forget to service the oil cooler as well and flush the cooling system properly" spiel. Upon questioning them they admitted to the mistake. Quote Link to comment Share on other sites More sharing options...
