kevin phillips Posted July 27, 2009 Share Posted July 27, 2009 Anybody know what the ground is for on rear drivers intake manifold stud?I have one with some crazy starting issues at times and found the ground not connected and was wondering what issues could be caused by it.Is it a ficm ground?thanks guys i haven't been able to found any references to it in the shop manual. Quote Link to comment Share on other sites More sharing options...
Keith Browning Posted July 27, 2009 Share Posted July 27, 2009 That is ground G110 and it is the fuel injector harness shield ground. The ground wire is loosely wrapped around the injector circuits and is also in contact with that foil tape that the harness is wrapped in. The shielding is to reduce or eliminate RF interference which can create stray voltage. Quote Link to comment Share on other sites More sharing options...
kevin phillips Posted July 27, 2009 Author Share Posted July 27, 2009 thanks keith i reattached it,still screwing up setting cmp codes think i'm gonna yank it and see how much rust is there where the sensor mounts. Quote Link to comment Share on other sites More sharing options...
Aaron Posted July 30, 2009 Share Posted July 30, 2009 Might need a harness, check the harness between the takeout near the fuel filters and the cam sensor, they chafe up against the fuel lines and shit, I've seen that a lot. Same with the front intake bolt on that side, they crush the harness there quite frequently, also. Quote Link to comment Share on other sites More sharing options...
