raw coolant in intake
Had one in with way overfilled crankcase and raw coolant in the air intake accordian before the primary turbo.....
nice clear clean coolant :S
replaced the turbos front cover water pump........ect...ect
came in after road test sat in shop overnight still losing pressure 10 psi over night 18 over the weekend.....
removed VCs to find nothing then removed the pan and found leak in between # 2 and #4 cylinders on the #2 side removed head no cross hatch on #2 and a cracked block.........
